When I go to install the plug in the install fails (70%) appears to be a chromium install issue
Need to get 1045 kB/126 MB of archives.
After this operation, 401 MB of additional disk space will be used.
Err:1 http://mirror1.ku.ac.th/raspbian/raspbian buster/main armhf libnss3 armhf 2:3.42.1-1+deb10u6
404 Not Found [IP: 158.108.4.211 80]
Installation of Chromium failed
Plugin failed to install!
Cleaning up…
I saw other posts saying this was a result of having a USB device connected, or a keyboard… I have disconnected the screen and touch links, back to headless with DAC+ Hat and exactly the same error seems to happen.
Testing the touch display:
This one is failing due to an earlier reported issue with the date setting.
volumio@volumioe30ii:~$ sudo apt-get update
Get:1 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:3 https://deb.nodesource.com/node_14.x buster InRelease [4584 B]
Reading package lists... Done
E: Release file for http://raspbian.raspberrypi.org/raspbian/dists/buster/InRele ase is not valid yet (invalid for another 9d 4h 22min 47s). Updates for this rep ository will not be applied.
E: Release file for http://archive.raspberrypi.org/debian/dists/buster/InRelease is not valid yet (invalid for another 9d 19h 36min 44s). Updates for this repos itory will not be applied.
Hence my request for a full log
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/download/touch_display/3.3.7/volumio/buster/armhf
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/download/touch_display/3.3.7/volumio/buster/armhf
Creating install location
Unpacking plugin
Checking for duplicate plugin
Copying plugin to location
Installing fake packages for kernel, bootloader and pi lib
Selecting previously unselected package libraspberrypi0.
(Reading database ... 36562 files and directories currently installed.)
Preparing to unpack .../libraspberrypi0_0.0.1_all.deb ...
Unpacking libraspberrypi0 (0.0.1) ...
Setting up libraspberrypi0 (0.0.1) ...
Selecting previously unselected package raspberrypi-bootloader.
(Reading database ... 36566 files and directories currently installed.)
Preparing to unpack .../raspberrypi-bootloader_0.0.1_all.deb ...
Unpacking raspberrypi-bootloader (0.0.1) ...
Setting up raspberrypi-bootloader (0.0.1) ...
Selecting previously unselected package raspberrypi-kernel.
(Reading database ... 36570 files and directories currently installed.)
Preparing to unpack .../raspberrypi-kernel_0.0.1_all.deb ...
Unpacking raspberrypi-kernel (0.0.1) ...
Setting up raspberrypi-kernel (0.0.1) ...
Putting on hold packages for kernel, bootloader and pi lib
libraspberrypi0 set on hold.
raspberrypi-bootloader set on hold.
raspberrypi-kernel set on hold.
Get:1 http://raspbian.raspberrypi.org/raspbian buster InRelease [15.0 kB]
Get:2 http://archive.raspberrypi.org/debian buster InRelease [32.6 kB]
Running apt-get update failed
Cleaning up...
Removing dependencies
Building dependency tree...
Reading state information...
Package 'fonts-arphic-ukai' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 16 not upgraded.
Package 'fonts-arphic-gbsn00lp' is not installed, so not removed
Package 'fonts-unfonts-core' is not installed, so not removed
Canceled hold on libraspberrypi0.
Canceled hold on raspberrypi-bootloader.
Canceled hold on raspberrypi-kernel.
Package 'chromium-browser' is not installed, so not removed
Package 'openbox' is not installed, so not removed
Package 'xinit' is not installed, so not removed
The following packages will be REMOVED:
libraspberrypi0*
0 upgraded, 0 newly installed, 1 to remove and 15 not upgraded.
After this operation, 26.6 kB disk space will be freed.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 36574 files and directories currently installed.)
Removing libraspberrypi0 (0.0.1) ...
raspberrypi-bootloader*
0 upgraded, 0 newly installed, 1 to remove and 14 not upgraded.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 36570 files and directories currently installed.)
Removing raspberrypi-bootloader (0.0.1) ...
raspberrypi-kernel*
0 upgraded, 0 newly installed, 1 to remove and 13 not upgraded.
(Reading database ... (Reading database ... 5% (Reading database ... 10% (Reading database ... 15% (Reading database ... 20% (Reading database ... 25% (Reading database ... 30% (Reading database ... 35% (Reading database ... 40% (Reading database ... 45% (Reading database ... 50% (Reading database ... 55% (Reading database ... 60% (Reading database ... 65% (Reading database ... 70% (Reading database ... 75% (Reading database ... 80% (Reading database ... 85% (Reading database ... 90% (Reading database ... 95% (Reading database ... 100% (Reading database ... 36566 files and directories currently installed.)
Removing raspberrypi-kernel (0.0.1) ...
Deleting /opt/volumiokiosk.sh
Deleting /data/volumiokiosk
Done
Removing temporary directory /tmp/touch_display-2gi0JMTAOi
Close
OK so I managed that… install worked… enabled etc… Bench test (no audio connected) played from spotify and it appeared to be fine… cover art and looked to be playing… pause seemed to work (visually) etc.
Moved it to playback location, connected to amp, now spotify sees it and plays to it, but the playing now screen doesnt update, and the player controls dont seem to function but the touchscreen does work as you can access menu controls etc. Its more like the spotify → volumio connection is audio output only…
EDIT :: Now screen is working (with big lagtimes) and audio isnt… I found it had defaulted to HDMI but even having set it back to DAC output theres no sound…
Multiple reboots and restarts and poor sync (timing between web / spotify / screen) I am wondering if a 3B+ is too weak to do this smoothly ?? As an audio only streamer it was working (but I would get strange behavior on stop / next etc) but with the screen duty it feels sort of overloaded ?
Raspberry Pi 4 Model B Ram 4 GB
Version of Volumio : 3.512
Network: WLAN
Volumio Free account, Spotify Premium account.
Version of touch screen plugin : 3.3.7
touch screen 7 inch
Thank you in advance.
Looks like you forgot to install the “Touch Display” plugin.
The fact that you see the boot screen means that the addition in userconfig.txt is correct.
I uninstalled the plugin then reinstalled it. The display is now functioning thank you. However, whilst a mouse works, the touch function needs calibrating is this an option?
Thank you
