@michel8166 Do you have a chance to test if the screensaver still works with the display rotated by 90 deg.?
set to 90 degrees and now the problem is also present, it does not turn off, the screen flickers 2x briefly, so it does make an attempt to go out, but it does not go through.
by the way the touch is at 90 degrees outline.
okay, so it’s not just me / mine
- misery loves company, I guess…
Looks great
Thanks for testing!
Too bad… So although the display uses the same driver as the original Raspberry Pi Foundation Touchscreen it obviously behaves differently. The difference in behaviour is the more annoying as there doesn’t seem to be a way to distinguish one from the other by software.
I also tried 270 degrees, same problem. then there is indeed a difference compared to the Raspberry Pi Foundation touchscreen.
Shame.
It would be interesting for me to know if this also applies to the Pi 3, which has different video hardware than the Pi 4.
I can test this if you want but not before tonight.
That would be great.
got to test it a little earlier.
okay a fresh install of volumio2 on a raspberry pi 3b version 1.2.
touchscreen set to 90 degrees and 20 seconds timeout and no screensaver on.
and here also the same problem after 20 seconds the screen dims slightly also at 270 degrees it does not work.
only difference is that now the touch is good.
Thank you very much for your effort!
So at least the display behaves similarly “wrong” on Pi3 and Pi4 if rotation is set to 90 deg. (270 deg. will be no different) when the screen should enter DPMS mode “off”…
Although I don’t expect this to be a solution, but while you’re at it: Could you increase GPU mem to e.g. 64MB and check if it makes a difference?
set it to 64mb and it makes no difference.
Thank you, this confirms my expectation.
Hi Just to let you know.
I Just found the actual reason for the weird behavior of the touch part.
There is a new plugin “Now Playing” that messes up the touch calibration.
After enabling this one, the touch rotation was 180 deg rotated. disabling it the touch was back to normal.
@Wheaten Thank you for the hint!
I also installed it, maybe this explains the problem with the touch. will test it tonight.
Yep, I saw you had the same brand.
Just remove both “Now Playing” and “Touch Display”, reboot and install only “Touch Display”.
For me there is a bypass, as my model has a hardware button to rotate the touch orientation.
as far as I know that touch problem is only with me at 90 and 270 degrees 0 degrees is okay, 180 degrees I have not tried yet. will let you know tonight.
huo hup, opschieten…
Hahaha ik wil maar ben nu niet thuis
