Plugin to add CD playback [cdplayer]
Hi! It’s not possible to upgrade it as the plugin is not on the official plugin store. I suggest to uninstall the old version and install the updated one
OK, Thanks
may be a silly question- where can i download to test ?
Hey @Josh2000 , sent you a PM :inbox_tray:
thanx -
as a lifetime premium account user i don’t need it for myself, but for helping others
great
br
Josef
I didn’t find Eject button in update-new version!?
It should be below all the audio tracks! anything there?
O.K. I am sorry, there it is!!! Everything works fluently!
Warm greetings
Tested on RPi 4B 1GB with Pi Touch Display 2 and Volumio 4.103 installed.
Works like a charm!
Thank you @matteo.tonini for all the effort you put on that!
Where can I find instructions how to install the plugin on volumio 4?
Hi @SO3D,
Here are the instructions, I can help you more in detail if you need :+1:
  1. Enable SSH Go to: http://volumio.local/dev → enable SSH
  2. In a terminal
ssh volumio@volumio.local
password: volumio
  1. Clone the repo
git clone https://github.com/matteo-tonini/volumio-plugins-sources-bookworm
cd volumio-plugins-sources-bookworm/cdplayer/
  1. Install and restart
volumio plugin install
volumio vrestart
  1. Now you should be able to activate the plugin on the UI
Hallo habe auf einem Raspberry Pi 3b mit Volumio 4.103 getestet
Funktioniert einwandfrei!
Vielen Dank an @matteo.tonini glg aus Villach
