Hi @nerd -
Thanks for taking time to analyze and explain what is going on with my setup. I will see if I can figure out how to report this to Spotify.
Cheers, Soren
Hi @nerd -
Cheers, Soren
Spotify queue available outside the Volumio UI?
Hi, I really enjoy the plugin. I show the upcoming Spotify tracks on a dashboard in Home Assistant (on a Google Nest Hub in the living room), so people can see what’s next without a phone.
Right now I get the queue by browsing the plugin’s page through the Volumio API. That works, but every time I do it, any Volumio app that’s open on that player jumps to the queue page. That’s annoying when someone is using the app at the same time.
Is there a way to make the Spotify queue available, for example through the REST API or some other route, without the open apps jumping to the queue? A simple read-only list of the upcoming tracks would be perfect for me.
Thanks again for the quick fix earlier!
Have you looked at the Volumio API?
http://<devices_ip_address>/api/v1/getQueue
Yes, but that does not show the spotify soloist queue, hence my question.
Hey @Sterke-Jerke,
Two queues are easy to mix up, so a couple of checks before any change.
Is Play Spotify tracks from the Volumio queue on? The Spotify Queue page on Browse exists only while that switch is on. Off, that page is not registered.
What exactly is Home Assistant calling? The path or socket message, and how often. /api/v1/getQueue is Volumio’s own queue. It will not list Soloist’s upcoming tracks, which matches what you saw.
When an app jumps, is it landing on Spotify Queue, and does it jump again later by itself while Home Assistant is quiet?
Thanks for the quick reply!
The switch is on. I’m not opening the Spotify Queue page directly though. Home Assistant browses soloist_connect and the upcoming tracks show up there. I’m not using getQueue.
It’s a REST browse call from Home Assistant. It runs once a minute and on every track change, but only while Spotify is playing. Afterwards I browse a dummy URI because I hoped that would stop the app from following along. It didn’t help.
Yes, it lands on the queue page, and only when Home Assistant fetches the list. When the player is on radio, Home Assistant doesn’t poll and the app stays where it is. As far as I can tell it doesn’t jump on its own in between.
I also found soloist ctl get_queue, but that only listens on localhost, so I can’t reach it from Home Assistant without SSH.
So a simple read-only way to get the upcoming tracks, without the apps jumping along, would be great.
Thanks!
Hey @Sterke-Jerke,
Thanks, that settles it. Your REST browse is the trigger, and it is a plugin defect, not Home Assistant.
What 0.9.1 does: the first browse of soloist_connect marks the page as open. From then on every track change and every queue_changed from Spotify rebuilds the page and broadcasts it as pushBrowseLibrary to every connected client, not just the one that asked. Volumio hands a plugin only the URI, never the caller, so there was no way to push to one client; the broadcast was wrong from the start. The flag is only cleared when a browse of a soloist_connect URI fails the check, so your dummy URI never reached this plugin and nothing was cleared. That is why it did not help.
Fixed in 0.9.2, on GitHub as of today. The page is a plain read: a browse asks Spotify for the full queue once, returns it to whoever asked, and nothing is pushed afterwards. A REST browse of soloist_connect has no side effects. Your once-a-minute poll and the on-track-change call both keep working and return the upcoming tracks; the apps stay where they are.
0.9.2 is not in the store. The store stays 0.9.1 until the next submission. To run it now: uninstall the store plugin, then install from GitHub (git sparse clone or alsa_soloist_connect-main.zip), armhf or x86.
One thing stays as it was: /api/v1/getQueue is Volumio’s own queue and will not show Soloist’s list. Browse soloist_connect is the read-only path you were after.
Please report back your test results as detailed as possible.
Hi @foonerd,
Thanks for the quick fix and the clear explanation. 0.9.2 solves it here.
I’m experiencing an intermittent playback issue with Spotify Soloist Connect on my Raspberry Pi 5 running Volumio 4.
Occasionally, when a song finishes, Soloist rapidly skips through numerous tracks in the Spotify playlist, playing approximately one second of each before eventually settling on a track much farther down the playlist.
I’ve experienced this several times, including today, October 30. I’ve also had an instance where playback simply stopped after a song instead of advancing.
My configuration:
I successfully submitted a Volumio diagnostic report immediately after today’s incident.
Could you advise how best to provide the diagnostic logs securely, and whether this resembles a known Soloist playback-state issue?
Thanks!
Hey UbdU, welcome.
I can’t help without the log. I have not been able to reproduce this here, so the log from your device is the only evidence available.
Please post the link from the log you submitted on 30 October. If you no longer have it, submit a new one straight after the next occurrence, as described here:
Keep verbose logging on, as you have it now, and give the approximate time the skipping started so I can find it in the log.
Thanks for the clarification about the API key.
Here’s the diagnostic log:
http://logs.volumio.org/volumio/pL1sJG6.html
The skipping occurred shortly before approximately 2:21 PM Eastern Time on October 30, 2026, based on when I reported the problem. I submitted the diagnostic log shortly afterward.
Verbose logging was enabled.
Thanks for investigating!
Hey @UbdU,
Thanks, that log has what was needed.
Both skip runs are in it: 14:16:05, and 14:20:08, which is the one you reported. Each starts at the natural end of a track and steps through about 20 tracks of the playlist in 4-5 seconds. Both stop on the same track, Joys Of The Emptiness.
During both runs the plugin sent no skip, play or pause, and neither did Volumio. As far as the log shows, the track changes come from Soloist itself, which is Spotify’s binary. The plugin only reports what Soloist tells it. The playback stop you mentioned is in there too (14:16:26 to 14:16:37), and Soloist reported that as well.
One thing would narrow it down. Let the same playlist run with the Spotify app on your phone fully closed, and say whether it still happens.
I wanted to try your plugin on my Raspberry Pi 3B+ to get lossless Spotify.
I asked Claude for help and we ended up with two pull requests on GitHub. I can’t say I fully understand them, and I couldn’t explain them either, but it works, and that’s enough for me! ![]()
I tested it on my Pi 3B+ with Volumio 3.912: lossless playback and the IR remote both work.
Thanks a lot for all your hard work, it made all this possible!
Hey @chrisp429,
Thank you for trying it on the Pi 3B+, and for testing it so thoroughly. Good to know lossless playback and the IR remote work on Volumio 3.912.
I can’t merge the two pull requests as they are. They were opened against main, which is the Volumio 4 (bookworm) release branch that everyone installs from, and both changes also affect Volumio 4, where they have not been tested yet. I have moved both to a separate feature/buster branch on GitHub, so nothing is lost.
What I need to work out now is how to bring buster support in cleanly through the release GitHub Actions, rather than merging it straight into the Volumio 4 release. I’ll update here when there is something to test.
If you want to try something else in future, just ask here first and I’ll set up a test branch for it.
Hi @nerd ,
Thanks for the quick reply, and for moving both pull requests to feature/buster instead of just closing them!
Sorry about opening them against main: it’s my first time contributing to a project, and I didn’t know how it works. I actually started this just for myself, then thought it might be useful to share, in case it helps someone else on Volumio 3.
I’ll ask first next time. If you need me to test anything on my Pi 3B+, just let me know.
Thanks again for all your work!
Specifically - @chrisp429 as promised, an update: Volumio 3 now has a best effort build of the plugin. The current release is v0.9.5.
What happened to your two pull requests:
Each release on GitHub now has two zips:
Release page: Release v0.9.5 · foonerd/alsa_soloist_connect · GitHub
To install on Volumio 3, put the -buster zip in /home/volumio on the player, then run:
mkdir -p /home/volumio/soloist_connect
cd /home/volumio/soloist_connect
miniunzip /home/volumio/soloist_connect-0.9.5-buster.zip
volumio plugin install
To update later, uninstall the plugin from the Volumio UI first, then install the new zip the same way.
Please note the terms for the Volumio 3 build:
To report a problem, say it is the Volumio 3 build, and give the Volumio version, the board, and the output of this command with the API key removed:
journalctl -u soloist -u volumio --no-pager
Thanks again for the report and the work behind it.
A short update, and a slightly unexpected one.
The shim that sits between Soloist and ALSA was written for Volumio and nothing else. Its default device is plug:volumio, and it was tested against Volumio’s chain. It turns out a shared library has no idea which distribution it is running on. The shim have been running by hand on piCorePlayer and moOde, with Soloist started from a shell or from systemd, and no Volumio anywhere near it.
They did not just run it. They broke it, properly and usefully.
Neither fault ever showed on Volumio. Volumio’s chain is simply too polite to report an underrun the way a plain hardware device does. The fixes go to everyone all the same.
What has changed as a result:
To keep this in proportion: it is a handful of users on other distributions, not those projects adopting anything. I have asked nobody to package it as a default while testing is open. Still, it is nice to see a Volumio component earn its keep elsewhere, and the bug reports have been better than some I write myself.
For Volumio users:
Thanks to ludoo and felipec84 for the reports, the patch and the patience.
