Actually, I take that back. I was just looking at the folder age (august 2024), though at the file level the date modified is April 2026. Perhaps I updated metadata since they were created.
That explains everything, thanks for letting me know! ![]()
I installed the plugin on one of my two Volumio units, it seems to be working well.
I like the way it appears with the other standard menu tiles, I like the time frame choices. and I like the way the music is displayed and the flexible way to browse through it.
Well done, I donāt know why Volumio couldnāt have added this functionality that many of have asked for over the years.
Thanks for your excellent feedback! Iām happy to see it closes that gap for you! ![]()
Iāll be looking into getting it released as stable soon. For that any further feedback will be appreciated, even if itās just āit worksā!
Thanks @Zhapox for the plugin!
Itās one of those really useful features for anyone who frequently adds music to their digital collection. I would have expected to find it built into Volumio by default, as it is in other systems (e.g., Navidrome), but the plugin works just fine, thanks!
Cheers @Zhapox , great plug-in.
As above why its not part of the default way Volumio works I dont know. I suppose you dont miss it if youāve never had it. With me its always been a case of ānow what was that album I added and said Iād listen tooā¦ā now its ahhhhh thatās the one.
Thanks again
@Ema82 & @M1ck: Thanks for your positive feedback! Glad to hear itās doing its job well at your end, too!
The plugin has now been released as stable in the plugin store (v0.5.3)! ![]()
Iāve been making a point of using it to find and play music on the system I added it to, itās been great.
Good news that itās now a proper release, Iāll update it and add it to the other Volumio installation.
Thanks for your work.
I uninstalled 0.4.4 but cannot install the newest one from the plugin store. This is the log that produces. How can I fix this?
Downloading plugin at https://plugins.volumio.workers.dev/pluginsv2/downloadLatest/recently_added/volumio/bookworm/armhf
END DOWNLOAD: https://plugins.volumio.workers.dev/pluginsv2/downloadLatest/recently_added/volumio/bookworm/armhf
Creating install location
Unpacking plugin
Checking for duplicate plugin
Copying plugin to location
An error occurred while installing the plugin TypeError: Cannot read properties of undefined (reading 'name')
Which version of Volumio are you using? The plugin is currently only released for Volumio 4.
I am running v4.119.
EDIT: I solved my problem. I thought I had deleted the recently_added folder from /data/plugins but it was still there. I deleted that and installed 0.5.3 without issue from the Volumio plugins list.
Glad you could fix it, thanks for letting me know! ![]()
