Beautifuly!
Very nice photos! Also, you found a small bug: the next track appears with a significant delay (about halfway through the currently playing track).
1920x480
Updated, made minor corrections, added 3 new skins
Update from 3.2.9 to 3.3.0, still have the problem.
Also, If I use Server only ( headless ), the local display spectrum sometimes seems unstable
( just flash, not up down, or the up down amplitude is lower than normal )
thank you.
I’ve got something!!! I’ve never used the “Random” option. I used it today and… in the “Interval” position it works fine, but in the “On Title Change” position - changing skins doesn’t work (it stays on one). I don’t know what it was like in previous versions (I haven’t used it).
RPI5, skin 1920x480, experimental 3.3.0
Is it just a photo or is that how they are displayed?
it should be like this:
This volume display is consistent with the volume control display on my Volumio.
When I turn the volume up to the maximum
I’m asking about the graphics. Is it cropped? (volume slider)
Uncropped, original screenshot. My screen resolution is 1920x1080.
This means the zipper/slider is cut off:
Image compression is done automatically by the Volumio website. I can send you the original image if you need it.
I have a question about the samplerate display. It was incomplete at first. I have modified meters.txt and increased the corresponding bandwidth, but it is still incomplete at first. However, it is normal after refreshing during playback.
Peppymeter-screensaver V3.3.0
@nerd @Gelo5
I tested it at all possible sampling rates. This effect has never occurred. It always displays at full value (sometimes it disappears altogether, but that’s VOLUMIO’s fault, not Peppymeter’s).
When I use my phone Tidal app to play the music on Volumio meters doesn’t move.
Any chance to fix that ?
Updated 1920x480, fixed minor bugs, added 3 skins. End
Poor photo, I can’t take nice ones like @Lee.Yan
PS.Paste Carl Orff’s music into your catalog and see how realistic it looks (cdart.png)
Hey @Gelo5,
Since I cannot reproduce on my end:
Please enable trace logging (debug.level = trace in the plugin settings) and check the PeppyMeter log for [pushState] TITLE CHANGE entries. If those appear but the meter doesn’t change, the issue is downstream in the main loop or Vumeter. If they DON’T appear, the socket.io connection or title detection has a problem. Or share /tmp/peppy_debug.log.
Hey @nerd
I don’t know what’s going on. I updated to 4.103 (Alpha) and the skin changes (Random-Title).
Magic!
http://logs.volumio.org/volumio/Xzh0Um1.html
peppy_debug.zip (3.3 KB)
For me, Random is a minor feature. The worst part is that I can’t find any bugs.!!!
Hey @Gelo5,
Except errors unrelated to peppy - all screensaver actions and APIs are in order.
Frankly - I do not share your pain :rofl:
