[PLUGIN] NanoSound CD plugin
for volumio 3 ?
yes :wink:
Hi Aiello,
sorry to bother you, but would you be so kind and tell the steps you took to make cd play work a little more detailed? I installed nanosoundcd and sg3-utils but this changed nothing for my install.
Thanks a lot!
you don’t need to install nanosound…in sg3-utils, the menu to the cd is only displayed when a cd is inserted…
I tried installing via method 2 and says Tinkerboard not supported. So I assumed .Volumio 3 is not supported.
I have the A&K CdRipper Mkii and was trying to see if there would be a difference in sound. Oh well, whenever it’s updated I’ll try.
Just ran the scrip again with a cd in my cd player, didn’t install because it was already installed.
it now shows in my installed plugins after restart…
to be clear, I used Aiello’s commands…
should nanosound working with Volumio 3.378_x86?
I installed because I want to playback cd but nothing is loading in Nanosound cd.
nanosoundcd_web.service - NanoSound CD Web Service
Loaded: loaded (/lib/systemd/system/nanosoundcd_web.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2022-11-02 15:42:12 UTC; 1min 30s ago
Main PID: 1530 (code=exited, status=1/FAILURE)
hi @Aiello ,
I am using commands you shared for getting external usb cd player in Volumio 3.
I haven’t installed any plugin, as you mentioned is not necessary, but even after restart and with a cd insterted in the player, I cannot see any cd menu.
External usb cd player is connected to the board over USB, i am also using an external power supply for the cd player to be sure it has enough power.
Is there something I am missing?
Thank you
is there way to use an old CD rom player with digital out?
thanks
Jem
Hello : mcarr6
Do you mean you can use nanosound CD on volumio 3 ?
Could you describe more detail on how to do it ?
I use Asus Tinkerboard with Volumio 2 and nanosound CD for a period and it works well.
2 days ago I upgrade to Volumio 3 and found the plugin not support.
So I downgrade to Volumio 2, but I can not install the nanosound CD plugin,
the volumio plugin install said
ā€œSorry, Tinkerboard is not supported via repository. Please visit NanoSound CD Plugin for Volumio – Support – Nanomesher for more detailā€
I also tried the SSH script method, but there seems some 404 missing file error.
Is there any method to re-install nanosound CD on tinkerboard/volumio 2 ?
or can anyone send the pre-config image with volumio 2 and nanosound CD for tinker board ?
thank you very much !!!
V2 of Volumio is out of support for a long time. Upgrade to V3.
The CD plugin is integrated in Volumio’s premium subscription.
Well, YOU only want cd play. But I only want multi-zone, so it’s just one simple feature, I should get it for free. The next guy only wants Tidal Connect, so he should get it for free…
Can you see where this is going?
@vmiguel
Couldn’t have said it better.
@RaspPifan
Please keep it friendly.
It all comes back to personal opinions.
You see the CD capability as a simple audio functions, others feel the same for Tidal connect.
The majority of functions are free, some are covered by a subscription.
IMHO what ever choice is being made by Volumio, there will always be people who disagree.
But paying a few euro’s, to keep the lights on, Infra running and food on people plates, see some great products come to market, for me it’s worth any penny.
Dear RaspPifan, why should my answer be ā€œprofessionalā€? I’m just a happy paying user.
Was it serious? Yes! A bit sarcastic maybe, but serious.
Is Volumio perfect? Of course not. But it’s been getting better over time. I’ve used it for several years now, first the free version, and when I wanted some features that were only with the subscription, I went for it.
Regarding my contribution to the forum, you can search.
And any ā€œsimple audio functionā€ requires code to work. I leave to the Volumio team to find the balance between the free and payed versions, and then I choose the version that fits my needs and means. If I go into a shop, I don’t usually ask for freebies, so why should software be any diferente?
Peace, and out.
