My dac are suptronic x5000
My setting are vanilla config and nanosound plugin
Hi all,
Regarding using internal audio jack (non i2s), we got volumio control working by using âHardwareâ mixer type and âPCMâ Mixer Control Name
Make sure the NanoSound CD upsampling set to disable as internal audio does not support it.
Hope this helps.
The /etc/asound.conf is just below (unchanged from auto reconfig audio):
defaults.pcm.card 0
defaults.ctl.card 0
defaults.pcm.rate_converter âsamplerateâ
pcm_slave.x4 {
pcm âhw:1,0â
rate 176400
pcm_slave.x2 {
pcm âhw:1,0â
rate 88200
pcm.rate_convertx4 {
type rate
slave x4
pcm.rate_convertx2 {
type rate
slave x2
We have written a list of recommended volume control options for different DACs here.
Hope this helps!
Hi
I attached an ide cd drive to volumio. The drive work, I can see list of tracks in volumio and even when click the play button the numbers are running, but no Audio comes out. Other audio from NAS/Spotify comes out a usual. How can I inspect this?
I canât get any CD to play.
Using lsusb, my player shows up as: Bus 001 Device 003: ID 13fd:0840 Initio Corporation INIC-1618L SATA.
Using ls /dev it is present as: sr0
This player works fine, both under Windows 10 and Linux Mint.
The âEject CDâ button in the plugin settings also works, but when inserting CDâs nothing happens.
The solution as posted by ThomasL fails due to missing dependencies.
The following packages have unmet dependencies:
libpam-systemd : Depends: systemd (= 215-17+deb8u8) but 215-17+deb8u7 is to be installed
systemd : Depends: libsystemd0 (= 215-17+deb8u7) but 215-17+deb8u8 is to be installed
E: Unmet dependencies. Try âapt-get -f installâ with no packages (or specify a solution).
Trying: apt-get -f install
Results in the following:
dpkg: warning: files list file for package âupmpdcli-qobuzâ missing; assuming package has no files currently installed
dpkg: warning: files list file for package ânetplugâ missing; assuming package has no files currently installed
dpkg: warning: files list file for package âtelnetâ missing; assuming package has no files currently installed
dpkg: warning: files list file for package âupmpdcli-gmusicâ missing; assuming package has no files currently installed
dpkg: warning: files list file for package âupmpdcli-tidalâ missing; assuming package has no files currently installed
(Reading database ⌠23000 files and directories currently installed.)
Preparing to unpack âŚ/systemd_215-17+deb8u8_armhf.deb âŚ
Unpacking systemd (215-17+deb8u8) over (215-17+deb8u7) âŚ
dpkg: error processing archive /var/cache/apt/archives/systemd_215-17+deb8u8_armhf.deb (âunpack):
trying to overwrite â/usr/share/dbus-1/system-services/org.freedesktop.systemd1.serviceâ, which is also in package systemd-shim 9-1
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
addgroup: The group `systemd-journalâ already exists as a system group. Exiting.
Processing triggers for dbus (1.8.22-0+deb8u1) âŚ
Errors were encountered while processing:
Please try the auto config audio function in NanoSound CD plug in settings and reboot.
If problem persist, please try share the output of
aplay -l
and also your /etc/asound.conf file.
thanks
Thank you ! it worked !
A little kick.
Iâve installed the latest updates for volumio, but nothing has changed. The player is still visible via lsusb and ls /dev, it responds to the eject command via the plugin settings and I hear CDâs spin up after loading them.
However, nothing happens in the GUI, I donât see any playlist appear and I donât hear any audio play.
Do you have an idea what might be the cause of the problem?
Iâm also attempting to get an Apple SuperDrive USB cd/dvd working with Nanosound CD pluging.
Iâve done the autoconfig and rebooted as it asked me to.
No luck
Iâve also tried the recommendations for sg_raw
No luck
The drive spins up and I can eject using the in app eject button.
When I try to rip a cd to Volumio it spins up and then aborts.
volumio@volumio:~$ cat /etc/asound.conf
#balbuzeâs config file
pcm.outparameq {
type ladspa
slave.pcm âplughw:1â
path â/usr/lib/ladspaâ
plugins [
id 2609
label âEqFA4pâ
input {
controls [ 1 79 2.22 2.5 1 400 0.93 2.5 1 3720 1.47 1.1 1 11400 1.62 2.5 -2 ]
pcm.outplugin {
type plug
slave.pcm "pcm.outparameq"
volumio@volumio:~$ cat /proc/asound/modules
0 snd_bcm2835
1 snd_soc_hifiberry_dacplus
7 snd_aloop
volumio@volumio:~$ cat /proc/asound/cards
0 [ALSA ]: bcm2835_alsa - bcm2835 ALSA
bcm2835 ALSA
1 [sndrpihifiberry]: HifiberryDacp - snd_rpi_hifiberry_dacplus
7 [Loopback ]: Loopback - Loopback
Loopback 1
volumio@volumio:~$ aplay -l
Subdevices: 7/7
Subdevice #0: subdevice #0
Subdevice #1: subdevice #1
Subdevice #2: subdevice #2
Subdevice #3: subdevice #3
Subdevice #4: subdevice #4
Subdevice #5: subdevice #5
Subdevice #6: subdevice #6
card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 IEC958/HDMI [bcm2835 IEC958/HDMI]
Subdevices: 1/1
card 0: ALSA [bcm2835 ALSA], device 2: bcm2835 IEC958/HDMI1 [bcm2835 IEC958/HDMI1]
Subdevices: 1/1
card 1: sndrpihifiberry [snd_rpi_hifiberry_dacplus], device 0: HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0 [HiFiBerry DAC+ Pro HiFi pcm512x-hifi-0]
Subdevices: 0/1
card 7: Loopback [Loopback], device 0: Loopback PCM [Loopback PCM]
Subdevices: 1/2
card 7: Loopback [Loopback], device 1: Loopback PCM [Loopback PCM]
Subdevices: 2/2
volumio@volumio:~$
For the record I am connecting through a powered USB hub to a Pi4 with HiFiberry DAC+ Pro.
Thanks for your help.
Iâm having much the same issue as many of you.
I have an x86 running volumio (latest) and can play out its analogue or via my schiit modi3 dac just fine.
Plugin installs just fine. Interesting thing is the auto reconfig option when I have my output set the DAC doesnât result in a working asound.conf, however I can restore that by pointing it to âcard 5â instead of âcard Sâ.
The main issue is the Apple SuperDrive CD spins, reads and seems to play but there is NO audio â not via the DAC and not even via the in-built PCM.
How does the audio of the CD find its way to alsa? I canât seem to see where that connection is established so itâs difficult to troubleshoot.
Any ideas?
Glen.
Hi All,
We would like to post a troubleshooting guide for NanoSound CD here:
ls -al /dev/cdrom
It should return something like:
lrwxrwxrwx 1 root root 3 Jun 13 15:39 /dev/cdrom â sr0
also try ejecting the cdrom
eject /dev/cdrom
For any reason, if itâs not mounted on /dev/cdrom, you may try this to force mount
mount -r /dev/sr0 /dev/cdrom
In /etc/asound.conf, check that it has:
</data/nanosound_cd/asound.conf>
Then check the content of /data/nanosound_cd/asound.conf. In /data/nanosound_cd/asound.conf the content depends on your DAC. You can use
aplay -l
and
to check the card number of your sound card.
For almost all i2s DAC, it should be card 1, below is our /proc/asound/modules
0 snd_bcm2835
Above tells you that your DAC is in card 1. bcm2835 is the internal sound card of Pi.
Hereâs an example of /proc/asound/modules for our USB DAC
0 snd_bcm2835
5 snd_usb_audio
If you are using i2s DAC and card 1, then your /data/nanosound_cd/asound.conf should be as below:
defaults.pcm.card 1
defaults.ctl.card 1
defaults.pcm.rate_converter "speexrate_best"
pcm_slave.x4 {
pcm "hw:1,0"
rate 176400
pcm_slave.x2 {
pcm "hw:1,0"
rate 88200
type rate
slave x4
type rate
slave x2
If you are using USB DAC, for example card 5 , then your /data/nanosound_cd/asound.conf should be as below:
pcm_slave.x4 {
pcm "hw:1,0"
rate 176400
pcm_slave.x2 {
pcm "hw:1,0"
rate 88200
type rate
slave x4
type rate
slave x2
Remember to reboot after you change the asound related settings!
This is very important
Finally we hope this guide help you with all the troubleshooting!
If you need more help, you can also check out NanoSound CD Installation Guide
We have found the issue recent issue where NanoSound CD cannot load the song list when clicking on âNanoSound CDâ icon.
The issue is due to the FREEDB (one of the album database we use) has been shutdown.
We have released a fix for armv7 cpu include Raspberry Pi. Please reinstall NanoSound CD or use the Upgrade Version button from the NanoSound CD plugin screen.
x86 version will be coming.
Hi!
Has the fix for x86 been released? I have this exact problem. If it has not been released yet, can I tweak something manually to temporary fix it?
Hi, x86 version has been released with this fix.
Just reinstall Nanosound CD plugin. Thanks for the wait!
Even more good news! We have are now using a new CDDB which have improved the recent problems with fetching the CD meta. Please upgrade to 2020-08-09 version. It is available to both x86 and Pi platform.
Thank you gnudb team!
thanks!
The new version to extract artist and album names is now available in v1.2 for both x86 and arm versions.
More details are here
Hope you enjoy it!
@nanomesher,
Please help with my issue here:
Hi, have you tried using Mixer Control Name: PCM ?
Which DAC do you use?
The only two mixer options I have in volumio are software or none
Here are some of the config files from your website that you mention:
asound.conf
pcm.softvolume {
type plug
slave.pcm "softvol"
pcm.softvol {
type softvol
slave {
pcm "plughw:2,0"
control {
name "SoftMaster"
card 2
device 0
max_dB 0.0
min_dB -50.0
resolution 100
volumio@volumio:~$ cat /data/nanosound_cd/asound.conf
defaults.pcm.card 2
defaults.ctl.card 2
pcm_slave.x4 {
pcm "hw:2,0"
rate 176400
pcm_slave.x2 {
pcm "hw:2,0"
rate 88200
type rate
slave x4
type rate
slave x2
aplay -l
Subdevices: 4/4
Subdevices: 1/1
Subdevices: 1/1
card 1: Headphones [bcm2835 Headphones], device 0: bcm2835 Headphones [bcm2835 Headpho nes]
Subdevices: 3/3
card 2: sndrpirpidac [snd_rpi_rpi_dac], device 0: RPi-DAC HiFi pcm1794a-codec-0 [RPi-D AC HiFi pcm1794a-codec-0]
Subdevices: 0/1
0 snd_bcm2835
1 snd_bcm2835
2 snd_soc_rpi_simple_soundcard
bcm2835 ALSA
1 [Headphones ]: bcm2835_headphonbcm2835 Headphones - bcm2835 Headphones
bcm2835 Headphones
2 [sndrpirpidac ]: RPi-simple - snd_rpi_rpi_dac
snd_rpi_rpi_dac
