[PLUGIN] Display Configuration for x86
@balbuze
Oh boy, forgot this one.
Great to be able to disable the cursor and apply a screensaver. The default driver’s design philosophy appears to be: “Why hide the cursor when you can admire it forever?”
Forgot to add it is stable now :wink:
hi everyone!
found the issue with screen rotation without layout changing
on aged X86 tablet (originally at Linux) with 10" 1280x800 display at bios and volumio the screen is in the portrait position 800x1200, so laying on the left edge if use the tablet in horizontal display position
after rotating by this plugin “screen rotation” to 90CW I get same portrait position 800x1280 but straight vertical at horizontal display position, so I can scroll the screen but in dosnt cover full display area as resolution not switched to 1280x800.
is there any chance to add the command to not only to rotate the screen, but change layout from portrait to album and reverse?
means need smth like GUI to standard command “sudo xrandr -d :0 -o right (or left or inverted)”
PS also seems that plugin do not allow system to operate at custom X11 settings
Hey @alvabo,
I must admit I am not following. Advanced Settings are meant to handle the discrepancies what device reports vs manufacturing defaults targeting your setup exactly. Are you reporting a defect in the functionality? I have a feeling that you have not tried these. Please post screenshot of your advanced setting from your setup.
hi, this what I mean.
on tablet display and settings screen
also is it possible to add to UI button for screen off command?
in my case “export DISPLAY=:0 && xset dpms force off 2>/dev/null” works perfect via ssh
Hello!
Ok, but not sure it will be very convenient…
Going through the plugin settings to switch off the screen.
But no technical difficulties to add it.
I’ll have a look.
Display Configuration 1.0.0 is ready for testing: a rework from the ground up of the plugin @balbuze started. It runs on my devices bench (a GOLE 2 Pro with its DSI touch panel, numerous latops, tablets, and a VirtualBox guest); before it goes to the store I would like it on screens I do not have. Settings from the store’s 0.0.43 are carried over on the first start.
It also takes up what was asked in this thread. @alvabo, there is a “Panel mounting” setting for panels built in sideways, and a “Turn the screen off now” button; your tablet would be a good test of both. @Flowta, there is a fit that scales and moves the picture for screens that cut the edges, and the driver’s own underscan where the output offers it.
What is new
  • Every connected screen has its own section: the turn (normal, right, upside down, left, each with a mirror), the panel mounting as the kernel reports it with an override, the mode, the fit (scale and move) for screens that overscan, the driver’s underscan where the output has it, and a position when there is more than one screen.
  • Touch and pointer follow the turn of their screen, with an offset per device for controllers mounted differently from the panel. The touch matrix is also written to an Xorg InputClass, so it is right from the first frame after a display restart.
  • Named profiles (use, copy, rename, delete). A profile can follow the panel: the screen is turned by what the kernel reports about the panel’s mounting.
  • Backup, restore and reset. Backups live under Internal Storage and survive an uninstall.
  • Screensaver (screen off or xscreensaver, held off while music plays if you want), cursor hiding, brightness through the backlight where there is one, and a button that turns the screen off now.
  • Virtual machines: the hypervisor is recognised and a fixed resolution can be set for the guest.
  • Settings apply at once and the page refreshes itself. No browser hard refresh.
  • The console turns at once; the boot logo at the next start.
  • Eleven languages.
  • Under the hood: no shell strings, no password in the code; the few things that need root go through one small helper named in sudoers.
Who I am looking for
Anyone with Volumio 4 (bookworm) on x86 and a screen, and in particular:
  • GOLE 1 Pro / GOLE 2 Pro and similar mini PCs with a built-in panel
  • Chuwi and other tablets or convertibles, especially where the picture comes up sideways before any plugin
  • an HDMI TV or monitor that cuts the edges (overscan)
  • a laptop (lid switch, backlight)
  • two screens at once
  • VirtualBox, VMware, Proxmox/KVM guests
Install
Fresh install, over SSH as the volumio user:
mkdir -p ~/display_configuration && cd ~/display_configuration
wget https://github.com/foonerd/display-configuration/releases/download/v1.0.0/display_configuration-1.0.0.zip
miniunzip display_configuration-1.0.0.zip && rm display_configuration-1.0.0.zip
volumio plugin install
Then enable it on the Plugins page. The installer adds unclutter-xfixes and xscreensaver if the player lacks them, so it needs network and takes a minute.
If you already run the store’s Display Configuration 0.0.43, replace the last line, volumio plugin install, with:
volumio plugin update
volumio vrestart
Your settings are kept and migrated. The restart is needed because Volumio only loads plugin code on start.
Release page with the zip and its SHA-256: Release v1.0.0 · foonerd/display-configuration · GitHub
What to try
  1. Open the plugin’s settings. The first section, Profile, describes what the plugin sees: your screen, its mode, the panel mounting the kernel reports, your touch device. Does it match reality?
  2. Turn the screen each of the four ways and back. Does the picture follow at once, and the touch with it? Does the kiosk page lay itself out again?
  3. If the touch is off by a turn or a mirror, set the offset in “Touch and pointer” rather than the screen turn, and say which value made it right.
  4. Reboot once. Are the console text and the Volumio logo turned the same way as the screen? (The section “Boot console and splash” lets you set them apart if your device needs that.)
  5. Screensaver: screen off after your timeout, held off while playing if you set that; the cursor hidden if you set that; brightness if your device has a backlight.
  6. Restart the display from Maintenance. Is the touch right from the first frame?
  7. Make a backup, change something, restore it.
  8. If you have two screens or a virtual machine, say what you tried and what happened.
What to report
Good or bad, one post per device, with:
  • the device and screen (make, model, how the screen is connected: built-in panel, HDMI, DP, virtual machine)
  • the exact Volumio version (the number, not “latest”), and whether you installed fresh or over 0.0.43
  • what you set, what you saw, and what you expected instead
  • the diagnostics report: Maintenance, “Write a diagnostics report”, then over SSH:
cat /tmp/volumio-display-diagnostics.txt
Paste it whole. /tmp is cleared at every reboot, so write and copy the report before you reboot. It holds the settings, what the plugin sees (xrandr, xinput, DMI, kernel line), what it did, and the kiosk and Xorg log lines that matter. It names the device (DMI) and the screen (EDID); apart from the player’s hostname it holds nothing from your accounts or network settings.
If the plugin does not start or its settings page does not open, there is no report to write; send a log link from http://volumio.local/dev instead, taken before any reboot: How to send a log link for a bug report? | Volumio
Reports here, or on GitHub with the Test report form: Sign in to GitHub · GitHub
Known limits in this round
Not yet tried on a device: a panel the kernel knows to be mounted sideways (the “Panel mounting” override exists for the rest), a screen with a driver-side underscan property (AMD and Nouveau), two screens, a lid switch, xscreensaver as the saver, and the fixed resolution on a virtual machine with a KMS driver. Reports on exactly these are the most useful.
Going back
Uninstall 1.0.0 from the Plugins page (it removes everything it added except your backups) and install the store’s version again.
The new version of the plugin V1.0.0 by @nerd is now available as beta in the store!
As usual for a beta (this is mandatory), remove the previous version, reboot and install the beta.
Feedback welcome!
Haven’t been able to fully test it yet. but it does miracles on a VirtualBox image of Volumio.
Volumio x86 4.119 @ Irbis TZ 202 (Atom x5-Z8300/2gb/32gb eMMC/1Gb Lan/Wifi/BT/2 front cameras, device originally on Ubunty for face recognition)
Screen is 10” IPS 1280x800 with touch Goodix, DSI-1.
What to try
YES. Original screen “Normal” means portrait. With “Panel mounting= right side up” its become album.
YES for screen rotation, but after several turns screen goes off «display is not running…» at web gui on PC, only hard reset reboot helps
Cannot report for touch, but seems it works for rotation.
this is related with touch settings on this exact tablet under any OS – nix or windows((
YES if right (90) is set.
YES, brightness works. Turn screen off works, wakes from touch.
But screensaver works even during music playback with “Not while playing = On” (as on photo below)
Seems yes
Seems yes
volumio-display-diagnostics.txt (60.4 KB)
Clean install Volumio V4.239, Plugin V1.0.0
Dell 3189, EDP-1
Default:
Touch Rotation => OK
Mouse Rotation => OK
Console text => OK
Boot logo => OK
Inverted prior reboot:
Inverted after reboot:
Mouse Rotation => Inverted
Console text => Inverted
Boot logo => Inverted
Advanced settings:
Console => 180
Boot logo => 180
Reboot
volumio@dell-3189:~$ cat /tmp/volumio-display-diagnostics.txt
==== Display Configuration 1.0.0, 2026-11-03T16:03:16.786Z, dell-3189
==== Settings
"schema": 1,
"activeProfile": "default",
"profiles": {
"default": {
"name": "default",
"mode": "manual",
"outputs": {
"orientation": "inverted",
"panelOrientation": null,
"mode": null,
"fit": null,
"underscan": null,
"enabled": true,
"position": null
"inputs": {
"offset": "normal",
"output": null
"boot": {
"console": "inverted",
"splash": "inverted"
"screensaver": {
"type": "dpms",
"timeout": 120,
"notWhilePlaying": true,
"hideCursor": false
"brightness": 100,
"virtual": {
"enabled": false,
"resolution": "1280x720"
"debug": false
==== Probe
"xAvailable": true,
"outputs": [
"name": "eDP-1",
"connected": true,
"primary": true,
"active": true,
"geometry": {
"width": 1366,
"height": 768,
"x": 0,
"y": 0
"modeId": "0x44",
"rotation": "inverted",
"reflection": "normal",
"physical": {
"widthMm": 256,
"heightMm": 144
"rotationsSupported": [
"normal",
"left",
"inverted",
"right"
"reflectionsSupported": [
"x",
"y"
"properties": {
"Colorspace": {
"value": "Default",
"supported": [
"Default",
"BT709_YCC",
"XVYCC_601",
"XVYCC_709",
"SYCC_601",
"opYCC_601",
"opRGB",
"BT2020_CYCC",
"BT2020_RGB",
"BT2020_YCC",
"DCI-P3_RGB_D65",
"RGB_WIDE_FIXED",
"RGB_WIDE_FLOAT",
"BT601_YCC"
"range": null
"max bpc": {
"value": "12",
"supported": null,
"range": [
6,
12
"Broadcast RGB": {
"value": "Automatic",
"supported": [
"Automatic",
"Full",
"Limited 16:235"
"range": null
"panel orientation": {
"value": "Normal",
"supported": [
"Normal",
"Upside Down",
"Left Side Up",
"Right Side Up"
"range": null
"scaling mode": {
"value": "Full aspect",
"supported": [
"Full",
"Center",
"Full aspect"
"range": null
"link-status": {
"value": "Good",
"supported": [
"Good",
"Bad"
"range": null
"CTM": {
"value": "0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0",
"supported": null,
"range": null
"CONNECTOR_ID": {
"value": "115",
"supported": [
"115"
"range": null
"identifier": "0x41",
"crtc": 0,
"currentMode": {
"width": 1366,
"height": 768,
"interlaced": false,
"id": "0x44",
"clockMHz": 72.3,
"preferred": true,
"current": true,
"hSync": "+",
"vSync": "-",
"h": {
"width": 1366,
"start": 1414,
"end": 1446,
"total": 1526,
"skew": 0,
"clockKHz": 47.38
"v": {
"height": 768,
"start": 771,
"end": 777,
"total": 790,
"clockHz": 59.97
"refreshHz": 59.97
"preferredMode": {
"width": 1366,
"height": 768,
"id": "0x44",
"clockMHz": 72.3,
"preferred": true,
"current": true,
"hSync": "+",
"vSync": "-",
"h": {
"width": 1366,
"start": 1414,
"end": 1446,
"total": 1526,
"skew": 0,
"clockKHz": 47.38
"v": {
"height": 768,
"start": 771,
"end": 777,
"total": 790,
"clockHz": 59.97
"refreshHz": 59.97
"panelOrientation": "Normal"
"name": "HDMI-1",
"connected": false,
"primary": false,
"active": false,
"geometry": null,
"modeId": null,
"rotation": null,
"reflection": null,
"physical": null,
"normal",
"left",
"inverted",
"right"
"x",
"y"
"properties": {
"Content Protection": {
"value": "Undesired",
"supported": [
"Undesired",
"Desired",
"Enabled"
"range": null
"max bpc": {
"value": "12",
"supported": null,
"range": [
8,
12
"content type": {
"value": "No Data",
"supported": [
"No Data",
"Graphics",
"Photo",
"Cinema",
"Game"
"range": null
"Colorspace": {
"value": "Default",
"supported": [
"Default",
"SMPTE_170M_YCC",
"BT709_YCC",
"XVYCC_601",
"XVYCC_709",
"SYCC_601",
"opYCC_601",
"opRGB",
"BT2020_CYCC",
"BT2020_RGB",
"BT2020_YCC",
"DCI-P3_RGB_D65",
"DCI-P3_RGB_Theater"
"range": null
"aspect ratio": {
"supported": [
"Automatic",
"4:3",
"16:9"
"range": null
"Broadcast RGB": {
"supported": [
"Automatic",
"Full",
"Limited 16:235"
"range": null
"audio": {
"value": "auto",
"supported": [
"force-dvi",
"off",
"auto",
"on"
"range": null
"link-status": {
"value": "Good",
"supported": [
"Good",
"Bad"
"range": null
"CTM": {
"supported": null,
"range": null
"CONNECTOR_ID": {
"value": "123",
"supported": [
"123"
"range": null
"identifier": "0x42",
"currentMode": null,
"preferredMode": null,
"providers": [
"index": 0,
"id": "0x43",
"capabilities": "0xf",
"capabilityNames": [
"Source Output",
"Sink Output",
"Source Offload",
"Sink Offload"
"crtcs": 3,
"outputs": 2,
"associatedProviders": 0,
"name": "modesetting"
"inputs": [
"id": 9,
"name": "Wacom Pen and multitouch sensor Finger",
"kind": "absolute",
"matrix": "-1.000000, 0.000000, 1.000000, 0.000000, -1.000000, 1.000000, 0.000000, 0.000000, 1.000000",
"node": "/dev/input/event4"
"id": 11,
"name": "MSFT0001:00 04F3:303A Mouse",
"kind": "relative",
"matrix": "1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000",
"node": "/dev/input/event7"
"id": 12,
"name": "MSFT0001:00 04F3:303A Touchpad",
"kind": "relative",
"node": "/dev/input/event8"
"id": 18,
"name": "ImPS/2 Logitech Wheel Mouse",
"kind": "relative",
"node": "/dev/input/event9"
"dmi": {
"sys_vendor": "Dell Inc.",
"product_name": "Latitude 3189",
"product_version": "",
"board_vendor": "Dell Inc.",
"board_name": "0VG3TM",
"bios_vendor": "Dell Inc.",
"bios_version": "1.18.0",
"bios_date": "03/23/2022",
"chassis_type": "10"
"virt": {
"virtual": false,
"hypervisor": null,
"source": "systemd-detect-virt"
"cmdline": "BOOT_IMAGE=vmlinuz initramfs.clear splash plymouth.ignore-serial-consoles quiet loglevel=0 bootdelay=5 biosdevname=0 imgpart=UUID=1107f432-6b2f-4b6e-9ee3-0ee4c034f559 bootpart=UUID=6110-24B5 datapart=UUID=54cad1cf-cc62-470f-b51c-7795d79e62a9 hwdevice=x86 uuidconfig=syslinux.cfg,efi/BOOT/grub.cfg imgfile=/volumio_current.sqsh logo.nologo vt.global_cursor_default=0 acpi_backlight=native net.ifnames=0 use_kmsg=no initrd=volumio.initrd",
"rotationCfg": {
"plymouth": 180,
"fbcon": 2,
"video": "video=efifb",
"gfxpayload": null,
"unknown":
"backlight": {
"device": "intel_backlight",
"max": 96000,
"current": 96000
"fbconRotate": 2,
"tools": {
"xrandr": true,
"xinput": true,
"xset": true,
"unclutter-xfixes": true,
"unclutter": true,
"xscreensaver": false,
"xscreensaver-command": false,
"xscreensaver-settings": false
"errors":
"screen": {
"index": 0,
"minimum": [
320,
200
"current": [
1366,
768
"maximum": [
16384,
16384
==== Plan
"profile": "default",
"mode": "manual",
"steps": [
"layer": "x",
"output": "eDP-1",
"action": "rotate",
"rotate": "inverted",
"reflect": "normal"
"layer": "x",
"output": "eDP-1",
"action": "fit-reset"
"layer": "input",
"device": 9,
"action": "matrix",
"matrix": "-1 0 1 0 -1 1 0 0 1"
"layer": "boot",
"action": "rotation.cfg",
"plymouth": 180,
"fbcon": 2,
"video": null,
"gfxpayload": null
"layer": "session",
"action": "screensaver",
"type": "dpms",
"timeout": 120,
"hideCursor": false
"layer": "session",
"action": "brightness",
"percent": 100
"layer": "xorg",
"action": "fixed-resolution-remove"
"notes":
==== Last apply
"commands": [
"xrandr",
"--output",
"eDP-1",
"--auto",
"--rotate",
"inverted",
"--reflect",
"normal",
"--transform",
"none"
"xinput",
"set-prop",
"9",
"--type=float",
"Coordinate Transformation Matrix",
"-1",
"0",
"1",
"0",
"-1",
"1",
"0",
"0",
"1"
"changed":
"skipped":
"warnings":
"errors":
"rebootNeeded": false,
"geometryChanged": true
==== Kernel command line
==== rotation.cfg
set screen=plymouth=180
set efifb=video=efifb
set fbcon=fbcon=rotate:2
==== xrandr --verbose
Screen 0: minimum 320 x 200, current 1366 x 768, maximum 16384 x 16384
eDP-1 connected primary 1366x768+0+0 (0x44) inverted (normal left inverted right x axis y axis) 256mm x 144mm
Identifier: 0x41
Timestamp:  47606
Subpixel:   unknown
Gamma:      1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC:       0
CRTCs:      0 1 2
Transform:  1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0009e5e40600000000
011a0104951a0e780a7d709e5b579e27
19505400000001010101010101010101
0101010101013e1c56a0500016303020
360000901000001a9a1656a050001630
3020360000901000001a000000fe0031
52484e39804e56313136343300000000
00004101940110000009010a202000b0
Colorspace: Default
supported: Default, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, RGB_WIDE_FIXED, RGB_WIDE_FLOAT, BT601_YCC
max bpc: 12
range: (6, 12)
Broadcast RGB: Automatic
supported: Automatic, Full, Limited 16:235
panel orientation: Normal
supported: Normal, Upside Down, Left Side Up, Right Side Up
scaling mode: Full aspect
supported: Full, Center, Full aspect
link-status: Good
supported: Good, Bad
CTM: 0 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0
0 1
CONNECTOR_ID: 115
supported: 115
non-desktop: 0
range: (0, 1)
1366x768 (0x44) 72.300MHz +HSync -VSync *current +preferred
h: width  1366 start 1414 end 1446 total 1526 skew    0 clock  47.38KHz
v: height  768 start  771 end  777 total  790           clock  59.97Hz
1366x768 (0x45) 57.860MHz +HSync -VSync
h: width  1366 start 1414 end 1446 total 1526 skew    0 clock  37.92KHz
v: height  768 start  771 end  777 total  790           clock  48.00Hz
1280x720 (0x46) 156.125MHz -HSync +VSync DoubleScan
h: width  1280 start 1376 end 1512 total 1744 skew    0 clock  89.52KHz
v: height  720 start  721 end  724 total  746           clock  60.00Hz
1280x720 (0x47) 120.750MHz +HSync -VSync DoubleScan
h: width  1280 start 1304 end 1320 total 1360 skew    0 clock  88.79KHz
v: height  720 start  721 end  724 total  740           clock  59.99Hz
1280x720 (0x48) 74.500MHz -HSync +VSync
h: width  1280 start 1344 end 1472 total 1664 skew    0 clock  44.77KHz
v: height  720 start  723 end  728 total  748           clock  59.86Hz
1280x720 (0x49) 63.750MHz +HSync -VSync
h: width  1280 start 1328 end 1360 total 1440 skew    0 clock  44.27KHz
v: height  720 start  723 end  728 total  741           clock  59.74Hz
1024x768 (0x4a) 133.475MHz -HSync +VSync DoubleScan
h: width  1024 start 1100 end 1212 total 1400 skew    0 clock  95.34KHz
v: height  768 start  768 end  770 total  794           clock  60.04Hz
1024x768 (0x4b) 65.000MHz -HSync -VSync
h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.36KHz
v: height  768 start  771 end  777 total  806           clock  60.00Hz
960x720 (0x4c) 117.000MHz -HSync +VSync DoubleScan
h: width   960 start 1024 end 1128 total 1300 skew    0 clock  90.00KHz
v: height  720 start  720 end  722 total  750           clock  60.00Hz
928x696 (0x4d) 109.150MHz -HSync +VSync DoubleScan
h: width   928 start  976 end 1088 total 1264 skew    0 clock  86.35KHz
v: height  696 start  696 end  698 total  719           clock  60.05Hz
896x672 (0x4e) 102.400MHz -HSync +VSync DoubleScan
h: width   896 start  960 end 1060 total 1224 skew    0 clock  83.66KHz
v: height  672 start  672 end  674 total  697           clock  60.01Hz
1024x576 (0x4f) 98.500MHz -HSync +VSync DoubleScan
h: width  1024 start 1092 end 1200 total 1376 skew    0 clock  71.58KHz
v: height  576 start  577 end  580 total  597           clock  59.95Hz
1024x576 (0x50) 78.375MHz +HSync -VSync DoubleScan
h: width  1024 start 1048 end 1064 total 1104 skew    0 clock  70.99KHz
v: height  576 start  577 end  580 total  592           clock  59.96Hz
1024x576 (0x51) 46.500MHz -HSync +VSync
h: width  1024 start 1064 end 1160 total 1296 skew    0 clock  35.88KHz
v: height  576 start  579 end  584 total  599           clock  59.90Hz
1024x576 (0x52) 42.000MHz +HSync -VSync
h: width  1024 start 1072 end 1104 total 1184 skew    0 clock  35.47KHz
v: height  576 start  579 end  584 total  593           clock  59.82Hz
960x600 (0x53) 96.625MHz -HSync +VSync DoubleScan
h: width   960 start 1028 end 1128 total 1296 skew    0 clock  74.56KHz
v: height  600 start  601 end  604 total  622           clock  59.93Hz
960x600 (0x54) 77.000MHz +HSync -VSync DoubleScan
h: width   960 start  984 end 1000 total 1040 skew    0 clock  74.04KHz
v: height  600 start  601 end  604 total  617           clock  60.00Hz
960x540 (0x55) 86.500MHz -HSync +VSync DoubleScan
h: width   960 start 1024 end 1124 total 1288 skew    0 clock  67.16KHz
v: height  540 start  541 end  544 total  560           clock  59.96Hz
960x540 (0x56) 69.250MHz +HSync -VSync DoubleScan
h: width   960 start  984 end 1000 total 1040 skew    0 clock  66.59KHz
v: height  540 start  541 end  544 total  555           clock  59.99Hz
960x540 (0x57) 40.750MHz -HSync +VSync
h: width   960 start  992 end 1088 total 1216 skew    0 clock  33.51KHz
v: height  540 start  543 end  548 total  562           clock  59.63Hz
960x540 (0x58) 37.250MHz +HSync -VSync
h: width   960 start 1008 end 1040 total 1120 skew    0 clock  33.26KHz
v: height  540 start  543 end  548 total  556           clock  59.82Hz
800x600 (0x59) 81.000MHz +HSync +VSync DoubleScan
h: width   800 start  832 end  928 total 1080 skew    0 clock  75.00KHz
v: height  600 start  600 end  602 total  625           clock  60.00Hz
800x600 (0x5a) 40.000MHz +HSync +VSync
h: width   800 start  840 end  968 total 1056 skew    0 clock  37.88KHz
v: height  600 start  601 end  605 total  628           clock  60.32Hz
800x600 (0x5b) 36.000MHz +HSync +VSync
h: width   800 start  824 end  896 total 1024 skew    0 clock  35.16KHz
v: height  600 start  601 end  603 total  625           clock  56.25Hz
840x525 (0x5c) 73.125MHz -HSync +VSync DoubleScan
h: width   840 start  892 end  980 total 1120 skew    0 clock  65.29KHz
v: height  525 start  526 end  529 total  544           clock  60.01Hz
840x525 (0x5d) 59.500MHz +HSync -VSync DoubleScan
h: width   840 start  864 end  880 total  920 skew    0 clock  64.67KHz
v: height  525 start  526 end  529 total  540           clock  59.88Hz
864x486 (0x5e) 32.500MHz -HSync +VSync
h: width   864 start  888 end  968 total 1072 skew    0 clock  30.32KHz
v: height  486 start  489 end  494 total  506           clock  59.92Hz
864x486 (0x5f) 30.500MHz +HSync -VSync
h: width   864 start  912 end  944 total 1024 skew    0 clock  29.79KHz
v: height  486 start  489 end  494 total  500           clock  59.57Hz
700x525 (0x60) 61.000MHz +HSync +VSync DoubleScan
h: width   700 start  744 end  820 total  940 skew    0 clock  64.89KHz
v: height  525 start  526 end  532 total  541           clock  59.98Hz
800x450 (0x61) 59.125MHz -HSync +VSync DoubleScan
h: width   800 start  848 end  928 total 1056 skew    0 clock  55.99KHz
v: height  450 start  451 end  454 total  467           clock  59.95Hz
800x450 (0x62) 48.750MHz +HSync -VSync DoubleScan
h: width   800 start  824 end  840 total  880 skew    0 clock  55.40KHz
v: height  450 start  451 end  454 total  463           clock  59.82Hz
640x512 (0x63) 54.000MHz +HSync +VSync DoubleScan
h: width   640 start  664 end  720 total  844 skew    0 clock  63.98KHz
v: height  512 start  512 end  514 total  533           clock  60.02Hz
700x450 (0x64) 51.750MHz -HSync +VSync DoubleScan
h: width   700 start  740 end  812 total  924 skew    0 clock  56.01KHz
v: height  450 start  451 end  456 total  467           clock  59.96Hz
700x450 (0x65) 43.250MHz +HSync -VSync DoubleScan
h: width   700 start  724 end  740 total  780 skew    0 clock  55.45KHz
v: height  450 start  451 end  456 total  463           clock  59.88Hz
640x480 (0x66) 54.000MHz +HSync +VSync DoubleScan
h: width   640 start  688 end  744 total  900 skew    0 clock  60.00KHz
v: height  480 start  480 end  482 total  500           clock  60.00Hz
640x480 (0x67) 25.175MHz -HSync -VSync
h: width   640 start  656 end  752 total  800 skew    0 clock  31.47KHz
v: height  480 start  490 end  492 total  525           clock  59.94Hz
720x405 (0x68) 22.500MHz -HSync +VSync
h: width   720 start  744 end  808 total  896 skew    0 clock  25.11KHz
v: height  405 start  408 end  413 total  422           clock  59.51Hz
720x405 (0x69) 21.750MHz +HSync -VSync
h: width   720 start  768 end  800 total  880 skew    0 clock  24.72KHz
v: height  405 start  408 end  413 total  419           clock  58.99Hz
684x384 (0x6a) 42.625MHz -HSync +VSync DoubleScan
h: width   684 start  720 end  788 total  892 skew    0 clock  47.79KHz
v: height  384 start  385 end  390 total  399           clock  59.88Hz
684x384 (0x6b) 36.125MHz +HSync -VSync DoubleScan
h: width   684 start  708 end  724 total  764 skew    0 clock  47.28KHz
v: height  384 start  385 end  390 total  395           clock  59.85Hz
640x400 (0x6c) 41.750MHz -HSync +VSync DoubleScan
h: width   640 start  676 end  740 total  840 skew    0 clock  49.70KHz
v: height  400 start  401 end  404 total  415           clock  59.88Hz
640x400 (0x6d) 35.500MHz +HSync -VSync DoubleScan
h: width   640 start  664 end  680 total  720 skew    0 clock  49.31KHz
v: height  400 start  401 end  404 total  411           clock  59.98Hz
640x360 (0x6e) 37.250MHz -HSync +VSync DoubleScan
h: width   640 start  672 end  736 total  832 skew    0 clock  44.77KHz
v: height  360 start  361 end  364 total  374           clock  59.86Hz
640x360 (0x6f) 31.875MHz +HSync -VSync DoubleScan
h: width   640 start  664 end  680 total  720 skew    0 clock  44.27KHz
v: height  360 start  361 end  364 total  370           clock  59.83Hz
640x360 (0x70) 18.000MHz -HSync +VSync
h: width   640 start  664 end  720 total  800 skew    0 clock  22.50KHz
v: height  360 start  363 end  368 total  376           clock  59.84Hz
640x360 (0x71) 17.750MHz +HSync -VSync
h: width   640 start  688 end  720 total  800 skew    0 clock  22.19KHz
v: height  360 start  363 end  368 total  374           clock  59.32Hz
512x384 (0x72) 32.500MHz -HSync -VSync DoubleScan
h: width   512 start  524 end  592 total  672 skew    0 clock  48.36KHz
v: height  384 start  385 end  388 total  403           clock  60.00Hz
512x288 (0x73) 23.250MHz -HSync +VSync DoubleScan
h: width   512 start  532 end  580 total  648 skew    0 clock  35.88KHz
v: height  288 start  289 end  292 total  299           clock  60.00Hz
512x288 (0x74) 21.000MHz +HSync -VSync DoubleScan
h: width   512 start  536 end  552 total  592 skew    0 clock  35.47KHz
v: height  288 start  289 end  292 total  296           clock  59.92Hz
480x270 (0x75) 20.375MHz -HSync +VSync DoubleScan
h: width   480 start  496 end  544 total  608 skew    0 clock  33.51KHz
v: height  270 start  271 end  274 total  281           clock  59.63Hz
480x270 (0x76) 18.625MHz +HSync -VSync DoubleScan
h: width   480 start  504 end  520 total  560 skew    0 clock  33.26KHz
v: height  270 start  271 end  274 total  278           clock  59.82Hz
400x300 (0x77) 20.000MHz +HSync +VSync DoubleScan
h: width   400 start  420 end  484 total  528 skew    0 clock  37.88KHz
v: height  300 start  300 end  302 total  314           clock  60.32Hz
400x300 (0x78) 18.000MHz +HSync +VSync DoubleScan
h: width   400 start  412 end  448 total  512 skew    0 clock  35.16KHz
v: height  300 start  300 end  301 total  312           clock  56.34Hz
432x243 (0x79) 16.250MHz -HSync +VSync DoubleScan
h: width   432 start  444 end  484 total  536 skew    0 clock  30.32KHz
v: height  243 start  244 end  247 total  253           clock  59.92Hz
432x243 (0x7a) 15.250MHz +HSync -VSync DoubleScan
h: width   432 start  456 end  472 total  512 skew    0 clock  29.79KHz
v: height  243 start  244 end  247 total  250           clock  59.57Hz
320x240 (0x7b) 12.587MHz -HSync -VSync DoubleScan
h: width   320 start  328 end  376 total  400 skew    0 clock  31.47KHz
v: height  240 start  245 end  246 total  262           clock  60.05Hz
360x202 (0x7c) 11.250MHz -HSync +VSync DoubleScan
h: width   360 start  372 end  404 total  448 skew    0 clock  25.11KHz
v: height  202 start  204 end  206 total  211           clock  59.51Hz
360x202 (0x7d) 10.875MHz +HSync -VSync DoubleScan
h: width   360 start  384 end  400 total  440 skew    0 clock  24.72KHz
v: height  202 start  204 end  206 total  209           clock  59.13Hz
320x180 (0x7e)  9.000MHz -HSync +VSync DoubleScan
h: width   320 start  332 end  360 total  400 skew    0 clock  22.50KHz
v: height  180 start  181 end  184 total  188           clock  59.84Hz
320x180 (0x7f)  8.875MHz +HSync -VSync DoubleScan
h: width   320 start  344 end  360 total  400 skew    0 clock  22.19KHz
v: height  180 start  181 end  184 total  187           clock  59.32Hz
HDMI-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x42
Timestamp:  47606
Subpixel:   unknown
Clones:
CRTCs:      0 1 2
filter:
Content Protection: Undesired
supported: Undesired, Desired, Enabled
max bpc: 12
range: (8, 12)
content type: No Data
supported: No Data, Graphics, Photo, Cinema, Game
Colorspace: Default
supported: Default, SMPTE_170M_YCC, BT709_YCC, XVYCC_601, XVYCC_709, SYCC_601, opYCC_601, opRGB, BT2020_CYCC, BT2020_RGB, BT2020_YCC, DCI-P3_RGB_D65, DCI-P3_RGB_Theater
aspect ratio: Automatic
supported: Automatic, 4:3, 16:9
audio: auto
supported: force-dvi, off, auto, on
link-status: Good
0 1
CONNECTOR_ID: 123
supported: 123
non-desktop: 0
range: (0, 1)
==== xinput list
⎡ Virtual core pointer                          id=2    [master pointer  (3)]
⎜   ↳ Virtual core XTEST pointer                id=4    [slave  pointer  (2)]
⎜   ↳ Wacom Pen and multitouch sensor Finger    id=9    [slave  pointer  (2)]
⎜   ↳ MSFT0001:00 04F3:303A Mouse               id=11   [slave  pointer  (2)]
⎜   ↳ MSFT0001:00 04F3:303A Touchpad            id=12   [slave  pointer  (2)]
⎜   ↳ ImPS/2 Logitech Wheel Mouse               id=18   [slave  pointer  (2)]
⎣ Virtual core keyboard                         id=3    [master keyboard (2)]
↳ Virtual core XTEST keyboard               id=5    [slave  keyboard (3)]
↳ Video Bus                                 id=6    [slave  keyboard (3)]
↳ Power Button                              id=7    [slave  keyboard (3)]
↳ Sleep Button                              id=8    [slave  keyboard (3)]
↳ Wacom Pen and multitouch sensor Pen       id=10   [slave  keyboard (3)]
↳ Intel Virtual Buttons                     id=13   [slave  keyboard (3)]
↳ Intel HID events                          id=14   [slave  keyboard (3)]
↳ Intel HID 5 button array                  id=15   [slave  keyboard (3)]
↳ Dell WMI hotkeys                          id=16   [slave  keyboard (3)]
↳ AT Translated Set 2 keyboard              id=17   [slave  keyboard (3)]
==== Xorg snippets
== /etc/X11/xorg.conf.d/95-display-configuration-touch.conf
Written by the Display Configuration plugin: touch and pointer matrices, applied when X starts.
Section "InputClass"
Identifier "display-configuration Wacom Pen and multitouch sensor Finger"
MatchProduct "Wacom Pen and multitouch sensor Finger"
Option "TransformationMatrix" "-1 0 1 0 -1 1 0 0 1"
EndSection
==== volumio-kiosk.service
● volumio-kiosk.service - Start Volumio Kiosk
Loaded: loaded (/lib/systemd/system/volumio-kiosk.service; enabled; preset: enabled)
Active: active (running) since Tue 2026-11-03 18:00:55 CET; 57min left
Main PID: 1391 (startx)
Memory: 758.8M
CPU: 17.657s
CGroup: /system.slice/volumio-kiosk.service
├─1391 /bin/sh /usr/bin/startx /etc/X11/Xsession /opt/volumiokiosk.sh -- -keeptty
├─1455 xinit /etc/X11/Xsession /opt/volumiokiosk.sh -- /usr/bin/X :0 -keeptty -auth /tmp/serverauth.p7aNSViPs7
├─1456 /usr/lib/xorg/Xorg :0 -keeptty -auth /tmp/serverauth.p7aNSViPs7
├─1537 bash /opt/volumiokiosk.sh
├─1634 /usr/bin/ssh-agent /opt/volumiokiosk.sh
├─1811 /usr/bin/openbox --startup "/usr/lib/x86_64-linux-gnu/openbox-autostart OPENBOX"
├─1812 /usr/lib/chromium/chromium --show-component-extension-options --enable-gpu-rasterization --no-default-browser-check --disable-pings --media-router=0 --disable-dev-shm-usage --enable-remote-extensions --load-extension= --enable-remote-extensions http://localhost:3000 --kiosk --touch-events --disable-touch-drag-drop --disable-overlay-scrollbar --enable-touchview --enable-pinch --window-position=0,0 --disable-session-crashed-bubble --disable-infobars --disable-sync --no-first-run --no-sandbox --user-data-dir=/data/volumiokiosk --disable-translate --show-component-extension-options --disable-background-networking --enable-native-gpu-memory-buffers --disable-quic --enable-fast-unload --enable-tcp-fast-open --autoplay-policy=no-user-gesture-required --load-extension=/data/volumiokioskextensions/VirtualKeyboard/
├─2024 /usr/lib/chromium/chrome_crashpad_handler --monitor-self --monitor-self-annotation=ptype=crashpad-handler "--database=/root/.config/chromium/Crash Reports" "--annotation=channel=built on Debian GNU/Linux 12 (bookworm)" "--annotation=lsb-release=Debian GNU/Linux 12 (bookworm)" --annotation=plat=Linux --annotation=prod=Chrome_Linux --annotation=ver=150.0.7871.100 --initial-client-fd=5 --shared-client-connection
├─2026 /usr/lib/chromium/chrome_crashpad_handler --no-periodic-tasks --monitor-self-annotation=ptype=crashpad-handler "--database=/root/.config/chromium/Crash Reports" "--annotation=channel=built on Debian GNU/Linux 12 (bookworm)" "--annotation=lsb-release=Debian GNU/Linux 12 (bookworm)" --annotation=plat=Linux --annotation=prod=Chrome_Linux --annotation=ver=150.0.7871.100 --initial-client-fd=4 --shared-client-connection
├─2029 "/usr/lib/chromium/chromium --type=zygote --no-zygote-sandbox --no-sandbox --crashpad-handler-pid=2024 --enable-crash-reporter=,built on Debian GNU/Linux 12 (bookworm) --user-data-dir=/data/volumiokiosk --change-stack-guard-on-fork=enable"
├─2030 "/usr/lib/chromium/chromium --type=zygote --no-sandbox --crashpad-handler-pid=2024 --enable-crash-reporter=,built on Debian GNU/Linux 12 (bookworm) --user-data-dir=/data/volumiokiosk --change-stack-guard-on-fork=enable"
├─2057 "/usr/lib/chromium/chromium --type=gpu-process --no-sandbox --disable-dev-shm-usage --enable-gpu-rasterization --ozone-platform=x11 --enable-native-gpu-memory-buffers --crashpad-handler-pid=2024 --enable-crash-reporter=,built on Debian GNU/Linux 12 (bookworm) --user-data-dir=/data/volumiokiosk --change-stack-guard-on-fork=enable --gpu-preferences=WAAAAAAAAAAgAQAEAAAAAAAAAAAAAGAAQAAAAAAAAAABAAAAAAAAAAAAAAAAAAAAggAAAAAAAAAAAAAAAAAAACAAAAAAAAAAIAAAAAAAAAABAAAAAAAAAAgAAAAAAAAACAAAAAAAAAAIAAAAAAAAAA== --shared-files --metrics-shmem-handle=4,i,1474611515775708479,9762107385718074361,262144 --field-trial-handle=3,i,6838647054766420905,9527819576191491791,262144 --variations-seed-version --pseudonymization-salt-handle=7,i,8161022894735427488,17290972965613399150,4 --trace-process-track-uuid=3190708988185955192"
├─2061 "/usr/lib/chromium/chromium --type=utility --utility-sub-type=network.mojom.NetworkService --lang=en-US --service-sandbox-type=none --no-sandbox --disable-dev-shm-usage --disable-quic --crashpad-handler-pid=2024 --enable-crash-reporter=,built on Debian GNU/Linux 12 (bookworm) --user-data-dir=/data/volumiokiosk --change-stack-guard-on-fork=enable --shared-files=v8_context_snapshot_data:100 --metrics-shmem-handle=4,i,15732967748396059123,11302700647368519963,524288 --field-trial-handle=3,i,6838647054766420905,9527819576191491791,262144 --variations-seed-version --pseudonymization-salt-handle=7,i,8161022894735427488,17290972965613399150,4 --trace-process-track-uuid=3190708989122997041"
├─2077 "/usr/lib/chromium/chromium --type=utility --utility-sub-type=storage.mojom.StorageService --lang=en-US --service-sandbox-type=utility --no-sandbox --disable-dev-shm-usage --disable-quic --crashpad-handler-pid=2024 --enable-crash-reporter=,built on Debian GNU/Linux 12 (bookworm) --user-data-dir=/data/volumiokiosk --change-stack-guard-on-fork=enable --shared-files=v8_context_snapshot_data:100 --metrics-shmem-handle=4,i,4120850792352016992,16555937164508184021,524288 --field-trial-handle=3,i,6838647054766420905,9527819576191491791,262144 --variations-seed-version --pseudonymization-salt-handle=7,i,8161022894735427488,17290972965613399150,4 --trace-process-track-uuid=3190708990060038890"
├─2117 "/usr/lib/chromium/chromium --type=renderer --crashpad-handler-pid=2024 --enable-crash-reporter=,built on Debian GNU/Linux 12 (bookworm) --user-data-dir=/data/volumiokiosk --change-stack-guard-on-fork=enable --no-sandbox --disable-dev-shm-usage --autoplay-policy=no-user-gesture-required --touch-events --ozone-platform=x11 --lang=en-US --num-raster-threads=2 --enable-main-frame-before-activation --renderer-client-id=6 --time-ticks-at-unix-epoch=-1793725216595333 --launch-time-ticks=51878069 --shared-files=v8_context_snapshot_data:100 --metrics-shmem-handle=4,i,6471869360404502606,4011660182911553133,2097152 --field-trial-handle=3,i,6838647054766420905,9527819576191491791,262144 --variations-seed-version --pseudonymization-salt-handle=7,i,8161022894735427488,17290972965613399150,4 --trace-process-track-uuid=3190708991934122588"
└─2118 "/usr/lib/chromium/chromium --type=renderer --crashpad-handler-pid=2024 --enable-crash-reporter=,built on Debian GNU/Linux 12 (bookworm) --user-data-dir=/data/volumiokiosk --change-stack-guard-on-fork=enable --no-sandbox --disable-dev-shm-usage --autoplay-policy=no-user-gesture-required --touch-events --ozone-platform=x11 --lang=en-US --num-raster-threads=2 --enable-main-frame-before-activation --renderer-client-id=5 --time-ticks-at-unix-epoch=-1793725216595333 --launch-time-ticks=51884142 --shared-files=v8_context_snapshot_data:100 --metrics-shmem-handle=4,i,15017022043148687530,13343010725090365569,2097152 --field-trial-handle=3,i,6838647054766420905,9527819576191491791,262144 --variations-seed-version --pseudonymization-salt-handle=7,i,8161022894735427488,17290972965613399150,4 --trace-process-track-uuid=3190708990997080739"
Nov 03 18:00:55 dell-3189 startx[1456]: xorg-server 2:21.1.7-3+deb12u12 (
Nov 03 18:00:55 dell-3189 startx[1456]: Current version of pixman: 0.42.2
Nov 03 18:00:55 dell-3189 startx[1456]:         Before reporting problems, check http://wiki.x.org
Nov 03 18:00:55 dell-3189 startx[1456]:         to make sure that you have the latest version.
Nov 03 18:00:55 dell-3189 startx[1456]: Markers: (--) probed, (**) from config file, (==) default setting,
Nov 03 18:00:55 dell-3189 startx[1456]:         (++) from command line, (!!) notice, (II) informational,
Nov 03 18:00:55 dell-3189 startx[1456]:         (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Nov 03 18:00:55 dell-3189 startx[1456]: (==) Log file: "/var/log/Xorg.0.log", Time: Tue Nov  3 18:00:55 2026
Nov 03 18:00:55 dell-3189 startx[1456]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Nov 03 18:00:55 dell-3189 startx[1456]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
==== Kiosk log
Starting Kiosk
Waited 4 sec for Volumio UI
Openbox-Message: Unable to find a valid menu file "/var/lib/openbox/debian-menu.xml"
ERROR: openbox-xdg-autostart requires PyXDG to be installed
[1812:2039:1103/180107.044999:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1812:2039:1103/180107.046231:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1812:2039:1103/180107.201714:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1812:2039:1103/180107.677279:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[2057:2057:1103/180107.803266:ERROR:media/gpu/vaapi/vaapi_wrapper.cc:1796] vaInitialize failed: unknown libva error
[1812:2039:1103/180108.243394:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1812:2039:1103/180108.243474:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1812:1812:1103/180108.577562:ERROR:dbus/object_proxy.cc:572] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[1812:1812:1103/180108.577697:ERROR:dbus/object_proxy.cc:572] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[1812:2039:1103/180108.577855:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1812:2039:1103/180108.577920:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1812:1812:1103/180108.602823:ERROR:dbus/object_proxy.cc:572] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[1812:1812:1103/180108.613523:ERROR:dbus/object_proxy.cc:572] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[1812:1812:1103/180108.740169:ERROR:dbus/object_proxy.cc:572] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[1812:1812:1103/180108.741644:ERROR:dbus/object_proxy.cc:572] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[1812:2039:1103/180108.744034:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1812:1812:1103/180108.763248:ERROR:dbus/object_proxy.cc:572] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[1812:2039:1103/180108.763983:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1812:1812:1103/180108.765963:ERROR:dbus/object_proxy.cc:572] Failed to call method: org.freedesktop.DBus.Properties.GetAll: object_path= /org/freedesktop/UPower/devices/DisplayDevice: org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.UPower was not provided by any .service files
[1812:1812:1103/180108.773043:ERROR:dbus/object_proxy.cc:572] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[1812:2039:1103/180108.773221:ERROR:dbus/bus.cc:405] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are "tcp" and on UNIX "unix")
[1812:1812:1103/180108.846235:ERROR:dbus/object_proxy.cc:572] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
[1812:2040:1103/180116.435266:ERROR:google_apis/gcm/engine/registration_request.cc:291] Registration response error message: DEPRECATED_ENDPOINT
[1812:2040:1103/170209.740189:ERROR:google_apis/gcm/engine/registration_request.cc:291] Registration response error message: DEPRECATED_ENDPOINT
[1812:2040:1103/170308.420760:ERROR:google_apis/gcm/engine/registration_request.cc:291] Registration response error message: DEPRECATED_ENDPOINT
==== Xorg log
[    40.402] (II) modeset(0): Modeline "720x405"x59.0   21.75  720 768 800 880  405 408 413 419 +hsync -vsync (24.7 kHz d)
[    40.402] (II) modeset(0): Modeline "684x384"x119.8   42.62  684 720 788 892  384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[    40.402] (II) modeset(0): Modeline "684x384"x119.7   36.12  684 708 724 764  384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[    40.402] (II) modeset(0): Modeline "640x400"x119.8   41.75  640 676 740 840  400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[    40.402] (II) modeset(0): Modeline "640x400"x120.0   35.50  640 664 680 720  400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[    40.402] (II) modeset(0): Modeline "640x360"x119.7   37.25  640 672 736 832  360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[    40.402] (II) modeset(0): Modeline "640x360"x119.7   31.88  640 664 680 720  360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[    40.402] (II) modeset(0): Modeline "640x360"x59.8   18.00  640 664 720 800  360 363 368 376 -hsync +vsync (22.5 kHz d)
[    40.402] (II) modeset(0): Modeline "640x360"x59.3   17.75  640 688 720 800  360 363 368 374 +hsync -vsync (22.2 kHz d)
[    40.402] (II) modeset(0): Modeline "512x384"x120.0   32.50  512 524 592 672  384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[    40.402] (II) modeset(0): Modeline "512x288"x120.0   23.25  512 532 580 648  288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[    40.402] (II) modeset(0): Modeline "512x288"x119.8   21.00  512 536 552 592  288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[    40.402] (II) modeset(0): Modeline "480x270"x119.3   20.38  480 496 544 608  270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[    40.402] (II) modeset(0): Modeline "480x270"x119.6   18.62  480 504 520 560  270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[    40.402] (II) modeset(0): Modeline "400x300"x120.6   20.00  400 420 484 528  300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[    40.402] (II) modeset(0): Modeline "400x300"x112.7   18.00  400 412 448 512  300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[    40.402] (II) modeset(0): Modeline "432x243"x119.8   16.25  432 444 484 536  243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[    40.402] (II) modeset(0): Modeline "432x243"x119.1   15.25  432 456 472 512  243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[    40.402] (II) modeset(0): Modeline "320x240"x120.1   12.59  320 328 376 400  240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[    40.402] (II) modeset(0): Modeline "360x202"x119.0   11.25  360 372 404 448  202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[    40.402] (II) modeset(0): Modeline "360x202"x118.3   10.88  360 384 400 440  202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[    40.402] (II) modeset(0): Modeline "320x180"x119.7    9.00  320 332 360 400  180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[    40.402] (II) modeset(0): Modeline "320x180"x118.6    8.88  320 344 360 400  180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[    40.403] (II) modeset(0): EDID for output HDMI-1
[    40.403] (II) modeset(0): Output eDP-1 connected
[    40.403] (II) modeset(0): Output HDMI-1 disconnected
[    40.403] (II) modeset(0): Using exact sizes for initial modes
[    40.403] (II) modeset(0): Output eDP-1 using initial mode 1366x768 +0+0
[    40.403] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[    40.403] (==) modeset(0): DPI set to (96, 96)
[    40.501] (==) modeset(0): Backing store enabled
[    40.501] (==) modeset(0): Silken mouse enabled
[    40.575] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[    40.575] (==) modeset(0): DPMS enabled
[    40.576] (II) modeset(0): [DRI2] Setup complete
[    40.576] (II) modeset(0): [DRI2]   DRI driver: iris
[    40.576] (II) modeset(0): [DRI2]   VDPAU driver: va_gl
[    40.594] (II) modeset(0): Damage tracking initialized
[    40.594] (II) modeset(0): Setting screen physical size to 361 x 203
[    40.968] (**) Option "TransformationMatrix" "-1 0 1 0 -1 1 0 0 1"
[    47.428] (II) modeset(0): EDID vendor "BOE", prod id 1764
[    47.428] (II) modeset(0): Printing DDC gathered Modelines:
[    47.428] (II) modeset(0): Modeline "1366x768"x0.0   72.30  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (47.4 kHz eP)
[    47.428] (II) modeset(0): Modeline "1366x768"x0.0   57.86  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (37.9 kHz e)
[    47.478] (II) modeset(0): EDID vendor "BOE", prod id 1764
[    47.478] (II) modeset(0): Printing DDC gathered Modelines:
[    47.478] (II) modeset(0): Modeline "1366x768"x0.0   72.30  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (47.4 kHz eP)
[    47.478] (II) modeset(0): Modeline "1366x768"x0.0   57.86  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (37.9 kHz e)
[    47.495] (II) modeset(0): EDID vendor "BOE", prod id 1764
[    47.495] (II) modeset(0): Printing DDC gathered Modelines:
[    47.495] (II) modeset(0): Modeline "1366x768"x0.0   72.30  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (47.4 kHz eP)
[    47.495] (II) modeset(0): Modeline "1366x768"x0.0   57.86  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (37.9 kHz e)
[    47.745] (II) modeset(0): EDID vendor "BOE", prod id 1764
[    47.745] (II) modeset(0): Printing DDC gathered Modelines:
[    47.745] (II) modeset(0): Modeline "1366x768"x0.0   72.30  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (47.4 kHz eP)
[    47.745] (II) modeset(0): Modeline "1366x768"x0.0   57.86  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (37.9 kHz e)
[   139.953] (II) modeset(0): EDID vendor "BOE", prod id 1764
[   139.953] (II) modeset(0): Printing DDC gathered Modelines:
[   139.953] (II) modeset(0): Modeline "1366x768"x0.0   72.30  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (47.4 kHz eP)
[   139.953] (II) modeset(0): Modeline "1366x768"x0.0   57.86  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (37.9 kHz e)
[   139.987] (II) modeset(0): EDID vendor "BOE", prod id 1764
[   139.987] (II) modeset(0): Printing DDC gathered Modelines:
[   139.987] (II) modeset(0): Modeline "1366x768"x0.0   72.30  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (47.4 kHz eP)
[   139.987] (II) modeset(0): Modeline "1366x768"x0.0   57.86  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (37.9 kHz e)
[   140.003] (II) modeset(0): EDID vendor "BOE", prod id 1764
[   140.003] (II) modeset(0): Printing DDC gathered Modelines:
[   140.003] (II) modeset(0): Modeline "1366x768"x0.0   72.30  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (47.4 kHz eP)
[   140.003] (II) modeset(0): Modeline "1366x768"x0.0   57.86  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (37.9 kHz e)
[   154.793] (II) modeset(0): EDID vendor "BOE", prod id 1764
[   154.793] (II) modeset(0): Printing DDC gathered Modelines:
[   154.793] (II) modeset(0): Modeline "1366x768"x0.0   72.30  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (47.4 kHz eP)
[   154.793] (II) modeset(0): Modeline "1366x768"x0.0   57.86  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (37.9 kHz e)
[   154.827] (II) modeset(0): EDID vendor "BOE", prod id 1764
[   154.827] (II) modeset(0): Printing DDC gathered Modelines:
[   154.827] (II) modeset(0): Modeline "1366x768"x0.0   72.30  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (47.4 kHz eP)
[   154.827] (II) modeset(0): Modeline "1366x768"x0.0   57.86  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (37.9 kHz e)
[   154.843] (II) modeset(0): EDID vendor "BOE", prod id 1764
[   154.843] (II) modeset(0): Printing DDC gathered Modelines:
[   154.843] (II) modeset(0): Modeline "1366x768"x0.0   72.30  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (47.4 kHz eP)
[   154.843] (II) modeset(0): Modeline "1366x768"x0.0   57.86  1366 1414 1446 1526  768 771 777 790 +hsync -vsync (37.9 kHz e)
http://logs.volumio.org/volumio/TYPc1nN.html
As requested 2nd log:
http://logs.volumio.org/volumio/nAWKp6i.html
volumio-display-diagnostics.zip (10.1 KB)
Version 1.1.0 (beta)
Plot twist: GRUB wasn’t the only bootloader in town.
The very first community test, a Dell Latitude 3189 booting the Volumio stick in legacy BIOS mode, immediately found something interesting.
Volumio booted.
The plugin worked.
The display rotated.
But the console and boot logo? NOPE.
They remained proudly, stubbornly and almost offensively unrotated.
After some digging, the villain revealed itself:
SYSLINUX.
Legacy BIOS doesn’t take the GRUB route, so rotation.cfg was standing on the platform waiting for a train that was never going to arrive.
Added
  • Full legacy BIOS/syslinux handling.
  • The plugin detects whether we’re booting through UEFI/GRUB or legacy BIOS/syslinux.
  • On syslinux, the required plymouth=, video= and fbcon=rotate: tokens are applied directly to /boot/syslinux.cfg.
  • Only those tokens are touched. We’re rotating the screen, not performing open-heart surgery on your boot configuration.
  • The original line is backed up as syslinux.cfg.display-configuration.bak.
  • If a Volumio update restores the stock configuration, the plugin politely puts its settings back.
  • Default rotation leaves the stock file alone.
  • The Boot section now reports the actual boot path and whether the running kernel already has the requested settings.
  • “Restart needed” now comes from what the kernel is actually running, rather than what we hope it’s running.
  • Diagnostics now include the boot path and /boot/syslinux.cfg.
Fixed
And while we were already crawling around inside the boot process, another gremlin appeared.
During a cold boot, the system could first decide:
“Normal rotation it is!”
Then the display server started:
“Actually… rotate it!”
So the console could briefly rotate one way and then back again like it was trying to find a comfortable sleeping position.
Not anymore.
Boot rotation is now determined directly from the profile and written once. No display server required. No mid-boot gymnastics. No identity crisis.
Changed
Uninstall now cleans the plugin’s syslinux tokens from the kernel line before removing the helper.
Case closed.
Legacy BIOS conquered.
Sideways boot logos defeated.
