[PLUGIN] Display Configuration for x86
Hello!
We are proud to share with you a new plugin : Display configuration
Available on the store, for x86 HW and Volumio4 only.
A screenshot to have an idea…
This a first version, other features are coming.
Thank you @nerd @Wheaten @gkkpch
Feedback welcome!
Enjoy :wink:
:tada: :partying_face: :mirror_ball: :tada: :partying_face: :mirror_ball: :tada: :partying_face: :mirror_ball:
oh! this you the first downloader :face_with_diagonal_mouth: :grinning:
There might be a small chance :slight_smile:
Yes it’s working. :slight_smile:
Only needed to invert the screen, no need to touch the advanced settings.
Only the Hide mouse Cursor is not hiding the mouse cursor.
really?
it takes 3 seconds before it hides
Damn the dog, bad dog…
Hide Mouse Cursor must be ON…
euh… Almost impossible to see “Hide”
Sorry, I can’t do anything for you. :grinning:
It’s hidden on the screen!
Any way to add “disable-overscan=1” for HDMI on X86?
This is not for x86 but only RPI as far as I know. Am I wrong?
google “x86 xrandr overscan correction”, this may show some ways of adding it to the plugin, but no guarantee. I suggest to test this first using ssh on @pauljwells installation.
yes I found this too
Enable underscan (this usually shrinks the image by about 5%):
xrandr --output HDMI-1 --set underscan on
If underscan is not supported, you can manually resize the output:
xrandr --output HDMI-1 --transform 0.95,0,-10,0,0.95,-10,0,0,1
(Replace HDMI-1 with your actual display name).
To be tested. Then could be added in the plugin.
You’re right, it is RPi. I only have X86 running at the moment.
Correct, x86 out-of-the-box has been configured as a generic setup, this plugin is extremely valuable to add machine-specific settings and does it in its own way. Everything you read about RPi and config.txt or userconfig.txt is not x86-related and therefore completely irrelevant.
but do you need to underscan on your display?
Do you know if you’ll be putting this or adding an option to change the overscan amounts in the near future?
The screen I have just cuts off the edges
I have a version nearly ready. I try to push a beta tomorrow :wink:
Hello!
Display configuration v0.0.42 beta
  • add overscan. Use HW capabilities if available or fallback to software mode.(software mode still needs some ajustement…)
This is a beta. Remove previous, reboot, install beta.
Feedback welcome :wink:
Display configuration v0.0.43 beta
Thank you @balbuze
Missed your previous messages. Going to try it in the next couple days
