Hi
does anyone had a chance with a cheap drive from aliexpress?
Hi
I tested this usb CD drive.
In general CD drives draw quite significant power from USB port.
So itâs probably a good idea to use a (very well) externally-powered USB hub in-between PI and CD drive to avoid problems.
Yeah that right. But I had not a active hub by my hand. So I test it on my Pc.
But no matter ⌠The drive was already broken after 5 min.
I noticed a bug: if I open the CD drive while playing, the CD player plugin tries to keep playing. Once in a while it will all of a sudden play the bit it buffed. If I then insert another CD, it tries to continue the previous one, resulting in digital noise (glitches). Is it possible for the plugin to detect if a CD is ejected and if so to stop playing?
Something else is that I have to set the playback speed to at least 20x to get continues playback. Isnât that a bit high? I have an LG GP57 âultra slim portable DVD writerâ connected to a RPI3, running latest versions of Volumio and the CD player plugin.
Thank you very much for developing this plugin!
Sent from my ASUS_Z017D using Tapatalk
Which Volumio and plugin versions are you using?
First issue was supposedly fixed a while ago: please confirm if it is still there if you use all latest versions. You may enter issue in authorâs github page, so that he gets directly notified.
Second issue should be fixed with an updated MPD version: unfortunately it is not yet available on current Volumio: you may test with the older trial version in that referenced post.
Thank you for the reply! I have Volumio 2.389. I canât figure out which version of the cdplayer plugin I installed. I copied it from Dropbox link in the first post, but that one doesnât seem to be the same as the files as on GitHub (github.com/geeks-r-us/volumio-p ⌠e/cdplayer). How do I download the latest version? I searched through this topic, but I canât find a link. I also tried
git clone https://github.com/geeks-r-us/volumio-plugins/tree/f/cdplayer/plugins/music_service/cdplayer
, but that gives a ârepository not foundâ error.
Iâm sorry for asking stupid questions, but my Linux experience is rather limitedâŚ
so should have the fix, as author posted it after mentioning the fix.
You may want to try with older Volumio version mentioned in the second part of my previous post (with improved MPD), in case the issue reappeared with recent Volumio, or MPD fix also fixes this (did not test in a while).
You may then report in authorâs github in full details.
Hi, I had this cd player running a while ago and loved it. But after I had to reinstall volumio, Iâm not sure how to get this running without their drag and drop plugin installation. How do I do this? And is it stable with the most recent version of volumio?
Hi all - I registered to make this post. Thanks to @geeks-r-us , @macmpi , and other contributors!
I am new to Volumio but fairly experienced with Linux. After a bit of noodling around, hereâs my (working) method for installing the plugin from a fresh scratch installation of Volumio 2.411 on x86. Thereâs no reason, AFAIK that this method shouldnât also work on rpi.
Enable ssh via the DEV page (i.e.,http://volumio.local/DEV)
SSH with user volumio password volumio:
ssh volumio@volumio.local
Apply system updates:
apt-get update
apt-get upgrade
Install required build dependencies:
apt-get install make g++ libudev-dev
Update npm:
sudo npm install npm@latest -g
(Note, sudo will ask you for a password. Itâs volumio)
Clone the code from github:
git clone --single-branch -b f/cdplayer https://github.com/geeks-r-us/volumio-plugins.git
Switch to the plugin directory and install node modules:
cd volumio-plugins/plugins/music_service/cdplayer/
npm install
You will get some warnings from Nan::Maybe and ffi.
You will see and ERR notice about not being able to find static binaries for udev, but it should fall back to source complile with node-gyp. This is why we installed libudev-dev before, to get the correct headers for compiling.
Install typescript:
sudo npm install typescript -g
Compile index.js with typescript:
tsc index.ts
You will get some errors, but it should still leave you with index.js in the working directory.
At this point we can install the plugin using the volumio plugin tool:
volumio plugin install
Feel free to open another session and tail -f /var/log/volumio.log if you want to see whatâs going on.
Once the plugin install completes, you should be able to see it in the plug-in manager section of the UI (volumio.local/plugin-manager) under Installed Plugins. Set the slider to âOnâ and you should see the Active/Inactive indicator go green.
Confirm that you have the Audio CD source in the Browse section, and enjoy your CDs!
Hope this helps!
Please be very careful with
apt-get upgrade
It may actually ruin your volumio distro, because there are volumio-specific dependencies which could be destroyed.
apt-get update
should be enough
Otherwise, interesting work, going to try thisâŚ
Good call out. It doesnât seem to cause any catastrophic issues with a fresh, vanilla install, but caution is prudent.
Dear sir,
Thank you for your hard works. (I run latest beta 2.452)
I have followed the instructions and able to active CD Player plug-in on my Volumio(Pi3 - B).
I just have few questions to ask for your helps.
(1)the CD playback sometimes skipsâŚlike breaking up the song.
so, I wonder if I can increase the buffer/cache for CD playback?
*please let me know if there is another post that is about increasing buffer on playback (not DSD) by editing command line via puffy(SSH)?
*or if I use an USB CD Player that has independent power supply will solve this problem as this adds stability to the player?
(2)online metadata source for CD disc.
Some CDs that I play, such as ADELE 25, it will automatically show the album art when playing the CD disc, including the track title names.
But these are not available for some albums.
so, I want to ask if I can add more features to search more online metadata source, such as Discogs, GD3, Music Brainz, feedb?
*if there is another posts about online metadata, please let me know, as I cannot find it. I may have used the wrong searching words.
Your helps are very much appreciated.
Sincerely, esprithk
The cd plugin is really great except there some breaks. Is there possible to add all the tracks to play list instead of whole CD in the play list?
I tried to change the read speed to 20x. it is better. I need to put buffer to 2MB and 10% in order to minimize the breaks. I discover that the resampling to 24/192 is still working fine.
Updated.
I bought the latest Raspberry Pi3 B+, and it is faster which helps to minimize the CD skipping/songs breaking during CD playback.
It helps alot. But I still want to edit the buffer cache if possible.
Please tell me how do I edit the buffer?
Thx, much appreciated!
Updated:
After some research and testing,
I found out that I get best result by setting the buffer size and buffer before play LOWEST
Audio Buffer Size = 128KB
Buffer Before Play = 10%
Now, no more song breaking. Volumio plays CD music smoothly.
Hi, does anyone know how to update MPD independent to avoid lag when playing CDs?
I think the latest version if MPD will solve this issue.
(1) The best playback quality is to follow my reply above for the Playback setting in VOLUMIO
*without edit the âmpd.confâ
(2) However, if you want to edit the file manually,
a. in VOLUMIO, go to NETWORK, write down your VOLUMIOâs IP address
b. on your web browser, go to
"volumio/local/dev
SSH ==> ENABLED
c. open PUTTY, and enter your VOLUMIOâs IP address (PORT 22)
d. login user: volumio, password(default): volumio
*if you want to change password,
type âpasswdâ and change your login password for security.
e. here are some basic command for LINUX
To return to ROOT
cd /
To go to folder (start from ROOT)
cd /folder name
cd /folder name/sub-folder name/
To go to folder (if you are already inside a folder)
cd folder name
If you want to check the list of the folder/files
ls -a
OK, to edit a file (text editor) *such as for .conf files
sudo nano filename
For your question about mpd.conf
you can go to
cd /etc
sudo nano mpd.conf
or you can type
sudo nano /etc/mpd.conf
warning: if the text editor is empty, it means you are creating a new file âmpd.confâ, which means something is not right, usually it is because you are inside the wrong folder or still at ROOT. You must see some configuration text.
OK, inside mpd.conf
you will try to find
audio_buffer_size
buffer_before_play
remark: actually, this is the same as what you see on the Display of VOLUMIO SETTINGS.
This is why it is no point to do it.
in my experience and after I did some diggings of information on the internet,
it is actually better to set the number to the lowest instead of select the highest number.
*Additional note:
I upgrade to latest Raspberry Pi 3 B+ (2018) and it helps alot on stability and eliminate the CD skip issues.
Beside CD music playback by USB optical drive, I am able to add âTIDAL pluginâ and play lossless music from my TIDAL account.
(however, it does not sync with My Playlist. I am waiting for updates for âupmpdcliâ)
*You can do some search on volumio.org for TIDAL plug-in installation and activation (it is a built-in feature).
Warning: DO NOT UPDATE to latest Version 2.502, or else, TIDAL plug-in through 'volumio_mediaserver" feature will be disable.
You will need to pay monthly fee for âMyVolumioâ services for music streaming.
by the way, remember to turn SSH OFF (disabled) after you finished updating files.
Updated:
Someone replied that TIDAL plugin (through âvolumio_mediaserverâ) still works on Version 2.502
I need to find out why.
Anyway, I have changed to use âBubbleuPnPâ now.
(1) Install âBubbleuPnPâ for Volumio
(2) Install âBubbleuPnPâ on my Android smartphone (Sony Xperia)
Now, I can control all my music files on my smartphone and VOLUMIO playback.
through BubbleuPnP in my Sony Xperia, I can access both my NAS and my shared music folders in my Windows 10 PC remotely.
Hi guys. could you tell me which guide to follow for not having blocks in reading the cd player? do I have to do it by ssh or can I do it from web ui? Hello
