Plex and PlexAmp plugin
My plex amp not working after one time activation of the plugin.
Please find below my log:
Starting Live Log…
info: CorePlayQueue::getQueue
info: CoreCommandRouter::executeOnPlugin: system , getHwuuid
info: CALLMETHOD: music_service inputs serialMonitorAction [object Object]
info: CoreCommandRouter::executeOnPlugin: inputs , serialMonitorAction
info: Error : CoreCommandRouter::executeOnPlugin: No method [serialMonitorAction] in plugin inputs
info: CALLMETHOD: system_controller motivocontrol displaySelection [object Object]
info: CoreCommandRouter::executeOnPlugin: motivocontrol , displaySelection
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig eth0
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/ifconfig wlan0
info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateCheckEnabled
info: CoreCommandRouter::executeOnPlugin: metavolumio , getInfinityPlayback
info: Listing playlists
info: CoreCommandRouter::executeOnPlugin: updater_comm , getUpdateMessageCache
info: CoreCommandRouter::executeOnPlugin: wizard , getOnboardingWizard
info: CoreCommandRouter::executeOnPlugin: my_volumio , getMyVolumioToken
(node:1037) UnhandledPromiseRejectionWarning: TypeError: Cannot read property ‘query’ of null
at /data/plugins/music_service/plexamp/plex.js:182:28
at runMicrotasks ()
at processTicksAndRejections (internal/process/task_queues.js:93:5)
(node:1037) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see Command-line API | Node.js v22.4.1 Documentation). (rejection id: 4)
info: CALLMETHOD: system_controller my_volumio retreiveBackendEventStates undefined
info: CoreCommandRouter::executeOnPlugin: my_volumio , retreiveBackendEventStates
info: Received Get System Version
can any one help on this error
I too did have that problem on my rpi 5. I reinstalled everything, and i am running the developer version of volumio and the plugins on my Volumio install. After all of that i was able to install the plugin and get it working properly. I have also made a stand alone install with headless plexamp, and auto loading of chrome. I find that i like Volumio better, as it has features as the now playing screen and the possibility to show vu-meters etc.
Hi-
I can’t figure out how to even try this out - it’s not on the plugin screen for music services… where can I find it? Is there an “official” release yet?
Thanks,
John
You need to enable the test mode for plugins <ip-address>/dev , as it’s still in beta.
Thank you @Wheaten !!!
Now, I’m facing the same thing as others… Despite enabling Plexamp headless, it doesn’t show up as an endpoint. Am I going to have to go back to Ropieee?
Got my Volumio setup, having migrated from Raspbian with PlexAmp Headless and Spotify headless working flawlessly…this plugin just DOES NOT work.
I authenticated, and it somehow decides that only a portion of my audio libraries will show up and it won’t even install plexamp headless.
After uninstalling and reinstalling to test, it seems the plug in also leaves remnants behind.
I really wish I could contribute to this plugin as I am sure a lot of ppl using Volumio would love to properly integrate their PlexAmp into this streamer.
Iam not able to get connection to my actual plex server of my plexaccount.It shows old server which is not active /removed from my account linked to my plexaccount. Please advise how to resolve this issue
Starting Live Log…
info: CoreCommandRouter::executeOnPlugin: plexamp , handleBrowseUri
info: plexamp
info: Preload queue cleared
My plex not gettinglinked to the plex account even after giving correct user account
Is this plugin working for anyone? The authentication process worked fine, Volumio ‘sees’ my server’s name but when I try to do anything it just says “server is unreachable”
Plugin Test mode is enabled in /dev
Installed version: 1.0.3(beta)
Between this and the recent failures of the YTM plugin, I’m starting to lose faith in Volumio as a solution. I will have to go back to my ChromecastAudio.
.ENORMOUS BUMP
…I’d really REALLY like plexamp headless to work…I wouldn’t then have to get an external digital source to work in volumio for a chromecast audio (that im going to have to buy).
I really like the plexamp Sonic Adventure feature (it’s er…cough better than the volumio equivalent…) and Im not adverse to paying for a headless plexamp plugin so that i can cast via the chromecast and the plexamp app on my phone…
<flashes a winning smile at @Jerome_O_Flaherty…>
I assume this plugin is no longer available? There is no Plex/PlexAmp plugin listed in Settings → Plugins, and
sudo volumio plugin install plexamp
just results in
No package found
If there’s some other way to install, please let me know.
I would also like to know. If I had known Plexamp wasn’t supported I would have never downloaded Volumio!
Actually, the guy who made the plugin hasn’t logged since 2023, so it might be dead in the water. Probably why it got removed. Unfortunate.
