I have two Volumio players. Both run on Raspberry Pi’s. One is running Volumio 2 (2.907) while the other is running Volumio 3 (3.785). Both use music from an NAS that is mounted to each one.
I have 10 playlist files. Once each one worked I copied them to the other system.
The problem is that the Volumio3 player will not play any of the playlists. But the Volumio2 player plays them all with no problem.
I have putty’d into each system and can see the playlists in the /data/playlist directory. The permissions, creation dates and sizes are all the same. At first observation, the playlist items seem to be identical.
I can look at the first song on a playlist on the Volumio3 player and navigate to the album and song and it plays just fine. So the connection to the NAS seems to be ok. I can also play albums on the Volumio3 player without problem.
So I’m trying to understand why the Volumio3 player does not play the songs in the playlist.
Other observations:
- when looking at the playlists on the Volumio2 player via the webpage, most (but not all) songs show the albumart icons, but the same playlist on the Volumio3 player shows the default icon for all songs
- albumart icons show up fine when looking at the list of albums
- the Volumio3 player had no problem playing the playlists until I upgraded it to Volumio3 (I have been through a couple of versions).
Looking for a clue as to why this is happening.
Thanks,
Rick
