Playing spotify playlists on console
Im am trying to play spotify playlist urls on console. how can i run spesific playlist on console? is there anyway to control spotify pugin on command line.
regards
maybe If you load spotify playlists to volumio playlists, then you can use REST API to play volumio playlist.
volumio.local/api/v1/commands/?cmd=playplaylist&name=Rock
Documentation is here volumio.github.io/docs/API/REST_API.html
I am trying to make rfid cards starts playing my spotify playlist. There is one tutorial for launching direct mp3s. But there is not any tutorial for controlling spotify. How can i make it?
Yep, you can try downloading web or music or spotify widget that allows you either to browse web sites or to operate with your spotify playlist. Or you can just directly download it to yours console storage from https://www.ps4storage.com and play it even offline whenever you like to.
