Playback stopped functioning
Anyone familar with these logs see anything obvious about ‘why’ I get no playback (spotify, youtube, anything) ??
[Vollibrespot] : Alsa error PCM open ALSA function ‘snd_pcm_open’ failed with error ‘EINVAL: Invalid argument’
[Vollibrespot] : Could not start audio: Alsa error: PCM open failed
It was working (but always seems to need multiple reboots of volumio / my desktop, etc etc when for no obvious reasons it will start working)… been away a couple of weeks, now nothing works…
Pi 3B+ IQAudioDAC+ line out…
Starting Live Log...
info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateCheckEnabled
info: Device is now in test mode
Test mode enabled
No alpha test mode
info: CoreCommandRouter::executeOnPlugin: my_volumio , getAutoUpdateEnabled
info: Update Ready: {"changeLogLink":"","description":"You're already on the latest version","title":"No Updates Available","updateavailable":false}
info: CoreCommandRouter::executeOnPlugin: updater_comm , setUpdateMessageCache
Soliciting pool server 2001:deb:0:4070::33
[Vollibrespot] : Connecting to AP "ap-gae2.spotify.com:443"
[Vollibrespot] : Authenticated as "seftonh" !
[Vollibrespot] : Using alsa sink
[Vollibrespot] : Metadata pipe established
[Vollibrespot] : Country: "TH"
[Vollibrespot] : Event: Volume { volume_to_mixer: 14784 }
[SpotifyConnect] Volume Spotify: 22.55893797207599 Volumio: 23
[Vollibrespot] : Event: SessionActive { became_active_at: 1702803658765 }
[Vollibrespot] : SessionActive!
[Vollibrespot] : Fetching autoplay context uri
[Vollibrespot] : Event: PlaybackStarted { track_id: SpotifyId { id: 220688590318136437930566313621872846373, audio_type: Track } }
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 220688590318136437930566313621872846373, audio_type: Track } }
[SpotifyConnect]  A connect session has begun
info: Acquiring new spotify session
info: CoreCommandRouter::volumioStop
info: CoreStateMachine::stop
info: Checking Spotify Web API
[SpotifyConnect] Vollibrespot Active
info: [1702803658774] ControllerSpotify::pushState
[SpotifyConnect]  Device palyback is active!
[SpotifyConnect]  Device palyback is loading
[Vollibrespot] : Autoplay uri resolved to <"spotify:station:playlist:37i9dQZF1E38XMDz9vh6o9">
[Vollibrespot] : Resolving uri "spotify:station:playlist:37i9dQZF1E38XMDz9vh6o9"
info: touch_display: Setting screensaver timeout to 0 seconds.
[Vollibrespot] : Event: GotToken { token: Token { access_token: "BQB08AM4oWZCzSkM6HsLFDmYsTtOB7g20h-ShxRxn935YPgxJ6GN0AbeAbQcPr14poW7uyGPB8N4toaP45o6k_GR7jsjUOAMNIlTM566RYELwgb8T9jl1P70lahNtsYfXNc9mmP3U2ltQmYEge0r1YUQk2rk1DTWxKoy_syzgttEndM4GYbgCqgxv-uBsCi-Pw", expires_in: 3600, token_type: "Bearer", scope: ["streaming", "user-read-playback-state", "user-modify-playback-state", "user-read-currently-playing", "user-read-private"] } }
[Vollibrespot] : ReqToken
info: New Spotify Access Token Received
info: Initializing Spotify Web API
[Vollibrespot] : Loading  with Spotify URI
info: touch_display: Using Xserver unix domain socket /tmp/.X11-unix/X0
[SpotifyConnect] Setting VLS device_id: d1387d4d45e42ffef0462b9f0896cc0f7b7c672d
[Vollibrespot] : Resolved 50 tracks from <"spotify:playlist:37i9dQZF1E38XMDz9vh6o9">
[Vollibrespot] :  (451733 ms) loaded
[Vollibrespot] : Alsa error PCM open ALSA function 'snd_pcm_open' failed with error 'EINVAL: Invalid argument'
thread '' panicked at 'called `Option::unwrap()` on a `None` value', /build/cache/git/checkouts/librespot-6f197fd632ef9380/08d8bcc/playback/src/audio_backend/alsa.rs:129:35
stack backtrace:
pcm512x 1-004c: ASoC: error at snd_soc_pcm_component_pm_runtime_get on pcm512x.1-004c: -22
 IQaudIO DAC: ASoC: error at __soc_pcm_open on IQaudIO DAC: -22
   0:   0xa58444 - std::backtrace_rs::backtrace::libunwind::trace::h40a4eff66330a36d
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/../../backtrace/src/backtrace/libunwind.rs:93:5
   1:   0xa58444 - std::backtrace_rs::backtrace::trace_unsynchronized::hbce01963451b0cd5
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/../../backtrace/src/backtrace/mod.rs:66:5
   2:   0xa58444 - std::sys_common::backtrace::_print_fmt::h95da650d09c7e00b
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/sys_common/backtrace.rs:66:5
   3:   0xa58444 - ::fmt::h33b23b1d14f668ff
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/sys_common/backtrace.rs:45:22
   4:   0xa810dc - core::fmt::write::h6320fb0e6ac90e58
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/core/src/fmt/mod.rs:1190:17
   5:   0xa504c4 - std::io::Write::write_fmt::h33b25d4810ca481f
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/io/mod.rs:1657:15
   6:   0xa5aef4 - std::sys_common::backtrace::_print::h7e61c5be69c715ef
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/sys_common/backtrace.rs:48:5
   7:   0xa5aef4 - std::sys_common::backtrace::print::h3cee176d7c8dab8b
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/sys_common/backtrace.rs:35:9
   8:   0xa5aef4 - std::panicking::default_hook::{{closure}}::h2d0211dd2e97dc43
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/panicking.rs:295:22
   9:   0xa5ab14 - std::panicking::default_hook::hcbdb3b7c40dca30c
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/panicking.rs:314:9
  10:   0xa5b694 - std::panicking::rust_panic_with_hook::h4ce49e7a343dc12b
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/panicking.rs:698:17
  11:   0xa5b360 - std::panicking::begin_panic_handler::{{closure}}::h4961100fae529fe9
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/panicking.rs:586:13
  12:   0xa589c4 - std::sys_common::backtrace::__rust_end_short_backtrace::hf2e68e62c7a80f1f
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/sys_common/backtrace.rs:138:18
  13:   0xa5b098 - rust_begin_unwind
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/panicking.rs:584:5
  14:   0x53e6f4 - core::panicking::panic_fmt::h84c42730e4a50809
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/core/src/panicking.rs:143:14
  15:   0x53e5c8 - core::panicking::panic::h929d4344847bfdba
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/core/src/panicking.rs:48:5
  16:   0x679158 - ::write::h2857e81996e06a1e
  17:   0x65b814 - ::poll::hf6331a81451dbb28
  18:   0x5836c0 - futures::task_impl::std::set::hb731921744f9247e
  19:   0x574708 - futures::task_impl::Spawn::poll_future_notify::h08f2c87ba9a4eead
  20:   0x588158 - std::sys_common::backtrace::__rust_begin_short_backtrace::hb598e9d2970dbf13
  21:   0x5b4e70 - core::ops::function::FnOnce::call_once{{vtable.shim}}::h7f140b0cfa5289e1
  22:   0xa5febc -  as core::ops::function::FnOnce>::call_once::hbc4d03a1815e028a
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/alloc/src/boxed.rs:1853:9
  23:   0xa5febc -  as core::ops::function::FnOnce>::call_once::h6055603e421418e8
  24:   0xa5febc - std::sys::unix::thread::Thread::new::thread_start::h0518d9d0e6b0ba31
                       at /rustc/7737e0b5c4103216d6fd8cf941b7ab9bdbaace7c/library/std/src/sys/unix/thread.rs:108:17
this looks like spotify plugin
is asla set oke?
Same thing for all plug ins… Youtube spotify etc… Nothing works and it was working and simply went on a holiday for a while…
ALSA ?? I am not familiar with this app so I am guessing you mean audio output ?? Its correctly set, as it was, for the IQAudioDAC+… No changes.
did you update volumio ? what version are you running?
asla is most of the time your audio settings from your dac what plugins are your running?
it could be that a plugin could giving problems.
do you have a premium account btw? you could ask for help if you have it.
No not premium… So far its not been really elegant / stable enough for me…
I use chromecast audios usually but thats not playing nice youtube / win 11 (seems a known issue) so still bouncing around options.
Honestly I wonder if the 3B+ has the power for it… At times it all seems a bit laggy and strange
do you use extentions on win11 for youtube?
will do a factory reset… was trying to avoid it as my default repo is not good so it needs to edit the sources etc… just all a hassle
adblockers…
RYS - Remove YouTube Suggestions , YouTube nonstop, costom scrollbar,scrollbar remover, better volume booster more tweaks like Ublock origin.
if you want to filter it all i have most of it filtered.
:slight_smile:
i have backup settings for RYS and for fire fox how to remove toasters.
what browser do you use FireFox or brave ?
only the start page is gone if you don’t consent your history:P
But spotify isnt working… As well as spotify, mixcloud, soundcloud, etc.
i would create a log
post the link so we can look for any problems…
http://logs.volumio.org/volumio/HmIb3aN.html
Seems the same thing
info: CorePlayQueue::getQueue
info: CoreCommandRouter::executeOnPlugin: system , getHwuuid
[Vollibrespot] : Event: SessionActive { became_active_at: 1702880846037 }
[Vollibrespot] : Event: PlaybackStarted { track_id: SpotifyId { id: 85309082760203731553003974797975915333, audio_type: Track } }
[Vollibrespot] : Event: PlaybackLoading { track_id: SpotifyId { id: 85309082760203731553003974797975915333, audio_type: Track } }
info: CoreStateMachine::serviceStop
info: CoreCommandRouter::serviceStop
info: [1702880846047] ControllerSpotify::pushState
[Vollibrespot] : Event: GotToken { token: Token { access_token: "BQDvSgeHhc7Ym-4GZf2S6We5FlMcVy2E7Wplr_9Je2Ay02ELxKPtuEzm3gaM1_rO1R4aSAqtcxTh37mr85QLzP_NONchdtDE34wYsW_bmFhu5edrXGjC2cDliurYQG7FpSkCkWhwVCCedPdeMrtxts9CJ3ZAy7a9xWt2m8a13mjifImuKEe5pSK4m8isFurvMw", expires_in: 3600, token_type: "Bearer", scope: ["streaming", "user-read-playback-state", "user-modify-playback-state", "user-read-currently-playing", "user-read-private"] } }
[Vollibrespot] :  (200000 ms) loaded
stack backtrace:
   0:   0xa28444 - std::backtrace_rs::backtrace::libunwind::trace::h40a4eff66330a36d
   1:   0xa28444 - std::backtrace_rs::backtrace::trace_unsynchronized::hbce01963451b0cd5
   2:   0xa28444 - std::sys_common::backtrace::_print_fmt::h95da650d09c7e00b
   3:   0xa28444 - ::fmt::h33b23b1d14f668ff
   4:   0xa510dc - core::fmt::write::h6320fb0e6ac90e58
   5:   0xa204c4 - std::io::Write::write_fmt::h33b25d4810ca481f
   6:   0xa2aef4 - std::sys_common::backtrace::_print::h7e61c5be69c715ef
   7:   0xa2aef4 - std::sys_common::backtrace::print::h3cee176d7c8dab8b
   8:   0xa2aef4 - std::panicking::default_hook::{{closure}}::h2d0211dd2e97dc43
   9:   0xa2ab14 - std::panicking::default_hook::hcbdb3b7c40dca30c
  10:   0xa2b694 - std::panicking::rust_panic_with_hook::h4ce49e7a343dc12b
  11:   0xa2b360 - std::panicking::begin_panic_handler::{{closure}}::h4961100fae529fe9
  12:   0xa289c4 - std::sys_common::backtrace::__rust_end_short_backtrace::hf2e68e62c7a80f1f
  13:   0xa2b098 - rust_begin_unwind
  14:   0x50e6f4 - core::panicking::panic_fmt::h84c42730e4a50809
  15:   0x50e5c8 - core::panicking::panic::h929d4344847bfdba
  16:   0x649158 - ::write::h2857e81996e06a1e
  17:   0x62b814 - ::poll::hf6331a81451dbb28
  18:   0x5536c0 - futures::task_impl::std::set::hb731921744f9247e
  19:   0x544708 - futures::task_impl::Spawn::poll_future_notify::h08f2c87ba9a4eead
  20:   0x558158 - std::sys_common::backtrace::__rust_begin_short_backtrace::hb598e9d2970dbf13
  21:   0x584e70 - core::ops::function::FnOnce::call_once{{vtable.shim}}::h7f140b0cfa5289e1
  22:   0xa2febc -  as core::ops::function::FnOnce>::call_once::hbc4d03a1815e028a
  23:   0xa2febc -  as core::ops::function::FnOnce>::call_once::h6055603e421418e8
  24:   0xa2febc - std::sys::unix::thread::Thread::new::thread_start::h0518d9d0e6b0ba31
info: CALLMETHOD: system_controller system sendBugReport [object Object]
info: CoreCommandRouter::executeOnPlugin: system , sendBugReport
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iwconfig
 volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/journalctl -p 7
info: Log sent successfully, reply: {"status":"OK","link":"http://logs.volumio.org/volumio/HmIb3aN.html"}
unless anyone has any great insight I will just do a full factory reset and rebuild it again…
OK… So I have now…
Pulled the screen off the Pi… Factory reset… Did the set up, as best I can remember exactly as I did before… Installed only the spotify plug in… and its still doing this
time=“2023-12-18T14:15:19+07:00” level=warning msg=“failed handling dealer request” error=“failed loading current track (transfer): failed creating stream: ALSA error at snd_pcm_open: Invalid argument”
time=“2023-12-18T14:15:19+07:00” level=debug msg=“skipping dealer message” uri=social-connect/v2/session_update
Something about the IQAudio / ALSA seems to fail
Full log here…
http://logs.volumio.org/volumio/2BdnA9Z.html
I mean I guess its conceivable my DAC hat has somehow failed ?? But it seems to me wildly unlikely.
http://logs.volumio.org/volumio/OQc94rg.html
It might be that the DAC is gone, or the contacts are oxidized… What about removing the DAC, use some contact cleaner and try connecting it again?
I will try… but its a 6 month old DAC… shiny new looking…
Headphones seem to work (I didnt actually conect to speakers but playback all appeared to connect and work) so its for sure something about the DAC.
http://logs.volumio.org/volumio/045m9kf.html
Because I cant remember how I set it up last time…
I should have (in playback options) I2S DAC enabled and IQAudio selected in that drop down ??
I also tried it selecting the DAC visible in I2S off and the IQAudio as one of the 3 options (headphones HDMI / DAC)…
Neither worked but I would like to confirm the first way is the ‘correct’ way ??
Yes but please select the correct DAC from the DAC menu
yeah sorry I should have included that bit but yes, obviously I selected the correct DAC.
I really struggle to believe the DAC has just gone bad (while off for 3 weeks)… But, thats what it seems like…
Thats a full reset and restore from cold now… Not much else to try… Will pull the DAC and clean pins but its barely used and shiny, I just struggle to see its failure…
