I am looking for suggestions of what hardware to add to my PI4B via its USB to obtain a large colour display suitable to show Volumio’s info.
rwilts
October 12, 2026, 1:12pm
2
Not exactly what you had in mind , but my best solution is to repurpose old iPads (other tablets would work) I just have them access the volumio via web browser.
Thanks, unfortunately I don’t have an old IPad !
Use a TV monitor. It works great.
AudioPete read this post - laptop with Intel N3060 with 11 cal touch screen - Volumio - 17.5 euro coast.
HP Pavilion X360 11-u000nf - Intel N3060 - 2GB RAM - 11,6" WXGA IPS Touch Display - 1366x768.
Volumio 4.119 - Glass 0.8.69
The touchscreen works right from installation, as does the laptop’s built-in audio.
Volumio is installed on the 32GB eMMC drive inside this HP unit.
The SD card reader also functions as mass storage a 64GB Sandisk SD card was tested.
The Glass plugin also works correctly after installation.
[image]
[image]
rwilts
October 12, 2026, 6:47pm
6
But looks like you need to buy something to deliver what you want. Old mobile also works but obviously smaller display.
True, I will have to buy something, I just want it to look good with my HiFi !
I built a Preamp in a Modushop Case which uses the following circuit boards from Djuke HiFi Audio:
5.1 Input board, CS3318 5.1 Channel volume Control, CS4398 DAC board, 6+2 Output buffer board, a Muffy RIAA preamp, Raspberry PI4B with a HiFi Berry Analogue HAT, and the PSUs to make it all work.
tweed77
October 13, 2026, 8:47am
10
@ AudioPete
At modushop.pl, you can order an enclosure with the option of having a cutout made for a display.
Read this post:
New streamer with 11,26 cal LCD HDMI with 43 cm aluminium case.
A cutout for the display was milled into the front panel using a CNC machine.
Working with Rotel A12
Raspberry Pi 4 - 4GB - GeeekPi 11.26 cal LCD HDMI ( 1920 x 440 IPS with touch ) - Khadas Tone2 maker kit - Mean Well RPS-60-5
Aluminium case - 43 cm x 9,2 cm x 30.8 cm
Plugin SerialAmpControl - Peppy Mater Basic - Now Playing
Aluminium Case:
GeeekPi LCD 11,26 HDMI with touch
[IMG_20260927_121639574_HDR (1)]
[IMG_202609…
Nice.
I used Modushop in Italy and they machined this for my Preamp.
