v3.912 installed on a Pi Zero 2w
I recently copied a folder/album onto the device (/data/INTERNAL/music) and the scanner wouldn’t pick it up. The folder was owned by volumio:volumio with execute permission for the owner only. I had to give group/other execute access before the volumio scanner would see the new files. Is this expected? Shouldn’t it be fine if the volumio user has access?
Either way, a message informing the user there are folders it can’t read would be super helpful as it was quite hard to track down the issue.
