Performance issue with boot from USB only after second boot
i have a very strange behavior, at first i thought it was an hardware problem with my raspberry 3B so i bought a new raspberry 4, as the problem was still here i change the external SSD and the problem persist.
Volumio version 3.742 - Raspberry 4 (or 3B) - External SSD (no sd cards)
It’s very simple : on a fresh install, when i first connect to volumio everything is fine, i use SMB share to transfer my music to internal storage (SSD USB) and i can transfert about 10Gb/hour.
At this point everything work as it should be until i shutdown the device. then at second boot (and next others), when i try to transfert music with SMB share, speed is about 100Mb/hour and i have SMB timeout, volumio interface is very slow.
i reproduce the problem with my 2 raspberry and 2 external SSD, i don’t understand the difference between the first boot after fresh install and all other boot.
