Volumio 3.703
Peppy spectrum latest one which you have shared to me
Spotify 4.0.4
Okey…sorry for disturbing you… Let me check the updated one ![]()
new list update…
Really happy…installed ![]()
working fine…
![20240706_222401|video]
(upload://vLhCPYQ7fTRpxMaJlkfGjpCXs2q.mp4)
I’m assuming as this is just the bars with no background (exactly what I’m looking for) I should be able to just modify the config file to get it to work with my 1920x720 display, correct?
Exactly. Just change bars width, space etc…
Hi… how can i make peppy spectrum as per my choice…?? LED color, LED size, etc… Can you please guide me how to edit the config .txt file?
Update the list. I added some 1980x720 Spectrums ![]()
just have a look inside the file spectrums.txt in the folder with your resolution.
Ok… Let me try… ![]()
Thank you! You da man.
Hi… Still peppy spectrum is not working or songs not playing while using spotify or youtube. But same time spectrum is working with radio channels… Expecting your help on this.
