OLED spectrum display on Volumio on Raspberry Pi Zero W
Hi Adrian
When webradio starts the next song the spectrum is shown but after 2 seconds it is stopped and watch is displayed. The spectrum is started after 10 seconds .
The code gives me a return only when spectrum is shown . When the music is playing and watch is shown no results for the code. The behaviour is reprodicible on every song switch
Blockquote
{“status”:“play”,“position”:0,“title”:“ARTHUR BAKER - THE MESSAGE IS LOVE”,“artist”:“Absolut Radio Relax”,“album”:null,“albumart”:“https://radio-directory.firebaseapp.com/volumio/src/images/radio-thumbnails/Absolut Relax.jpg”,“uri”:“http://stream.absolutradio.de/relax/mp3-160/radioplayer/“,“trackType”:“webradio”,“seek”:3613533,“duration”:0,“samplerate”:”“,“bitdepth”:”",“channels”:2,“bitrate”:"192 Kbps”,“random”:null,“repeat”:null,“repeatSingle”:false,“consume”:true,“volume”:“”,“mute”:false,“disableVolumeControl”:false,“stream”:true,“updatedb”:false,“volatile”:false,“service”:“webradio”}volumio
When I stop the music the status when running curl command is stop :
Hi Florin
Thanks for the extra details. That is the problem then. If mpd_oled can’t get the status values from Volumio then it doesn’t have any values to show, and so it displays the stop screen,
Adrian.
Hi Adrian,
Thanks. I can live with that but until now and on other version it was OK. Maybe volumio will improve… I will switch to buster in nearly future.
Regards.
Hi Adrian,
some time I ago you reported in the changelog that the bug of the screen divided in two part, shown with wrong order, was solved.
From time to time I still have it, using your latest version. Unfortunately I did not find a way to reproduce it, and also not a way to get rid of it without rebooting.
Hi Darmur
Thanks for reporting this.
It was previously reported as an issue (assuming this is the same problem), but I never fixed it as it did not seem to be affecting anyone else. Now that it is, I have reopened the issue and will see if I can fix it. I will post followups on the issue tracker.
Adrian.
many thanks!
I can add some more information:
  • Issue pops up mostly on Raspberry Pi Zero
  • I2C Bus speed 1MHz
  • Display with SSD1306 controller
I am available for testing eventual fixes, one of the systems I have shows this issue quite often
Hi Darmur
Could you please test a potential fix. It is included in a branch, which can be cloned with
git clone -b offset_fix https://github.com/antiprism/mpd_oled.git
[Check it is the right branch, main.cpp should include a call to reset_offset
grep reset_offset main.cpp
EDIT: I forgot to say, the display is corrected when the play state changes between play, pause, stop.
Adrian.
Sure, I will build this evening and test in the coming days, many thanks for your proposed fix!
I am testing right now the new version with the reset offset fix, so far so good.
Hello Adrian,
I am using the plugin with spotify volumio plugin. When listen to spotify the spectrum is not shown. Only the the Metadata is shown and when the song is stopped the plugin switch to watch.
With qobuz and webradio it is ok.
Thanks.
Hi Florin
mpd_oled requires a copy of the audio that is playing in order to show the spectrum bars. The installation instructions set up a copy using MPD, which means that the spectrum can only be seen when MPD is the player. It is possible to set up a copy of the audio for all sources by using a custom ALSA configuration file, but I can’t give specific instructions for this. See the following thread for more details:
Adrian.
Hello Adrian,
Thanks for tbe fast answer.
Spotify does not use mpd for playing? Also qobuz tidal webradio is working… Volumio team could also fix this? Is there something that will help?
I want to have only spotify because I do not see much differences from qobuz hi res… With my e30 dac.
Hi Florin
I believe it will be easier to make a copy of the audio from all sources in the next major update of Volumio
Adrian.
Hi Adrian,
OK, then I will wait :). Everything comes with a price. In my case no cava with spotify.
Regards
Florin
Nope, Spotify uses a custom daemon (spop/vollibrespot) to fetch encrypted audio directly from Spotify’s servers, and the proceeds to decrypt and play it. This wouldn’t be possible to do via mpd as it would go against Spotify’s Terms Of Service…
I have just pushed a major update to the mpd_oled repository to make the installation process easier.
https://github.com/antiprism/mpd_oled/bl.../README.md
Please let me know about about any issues.
There is no need to update an existing mpd_oled install as there are no new program features.
Adrian.
@Adrii
Been following this thread for a little while. Thanks for creating this and troubleshooting for everyone. Despite my limited technical knowledge, I’m going to give this screen a shot soon, but it appears your most recently posted github link is a dead end. Do you have an updated one?
Hi FradSevage
Thanks, I didn’t know the link wasn’t working. The main repository link (which also displays the README) is
Adrian.
You might wanna try my unofficial plugin which will installs Adrian’s software (from a slightly older but stable repository) and lets you configure the screen from within the volumio UI.
https://community.volumio.com/t/plugin-mpd-oled-installation-configuration-plugin
Awesome. Huge thanks to you, @supercrab, and @adrii both for creating this fun stuff, sharing it, and keeping it up to date and usable for all.
