OK to switch off the computer ?
is it OK to simply switch off a Raspberry running Volumio or do you risk damaging the filesystem on the SD card?
I tried the PC Volumio distribution in VirtualBox, overlayfs is active, but files in the volumio home directory do survive a reboot.
Thanks,
Juergen
PS: I could not access the Volumio vbox from the Windows host system, the spinner kept turning forever.
I had opened 80,3000 and 22 for NAT. Are there other ports necessary?
Hi weberjn,
there have been discussions about that -> https://volumio.org/forum/volumio2-shutdown-t8235.html (more are to find using the search)
I cannot help you with the other question. I recommend to open a separate thread for it.
Cheers
Pirx
