NUMBER OF ALBUM LIMITED IN MUSIC LIBRARY?
I mount my NAS containing 2T music to RPi 3B correctly. It will always reset to zero when it scans the nas up to about 1100 albums. My nas is Qnap using cifs to connect to Rpi3. I try Asus Tinker Board +Volumio. It can fully load 3077 album, but Rpi3B + volumio cannot. The settings are the same.
Already delete some non-music file in the NAS music directory. It does not work. Please help.
Please don’t keep making new posts about the same problem … add your comments to an existing one. I would suggest that you try and see if there is any information in the system logs at the time the library resets to zero. Ssh into the RPi, start the library scan going, and then input ‘sudo journalctl -f’ at the command line. You should then see all the logs as they happen, including hopefully any error messages.
thank you
