volumio@volumio:/tmp$ sudo gdebi -n /tmp/mpd-oled_0.2+202105121736+0e64706_armhf.deb
[sudo] password for volumio:
Reading package lists… Done
Building dependency tree
Reading state information… Done
(Reading database … 53929 files and directories currently installed.)
Preparing to unpack …/mpd-oled_0.2+202105121736+0e64706_armhf.deb …
Removed /etc/systemd/system/multi-user.target.wants/mpd_oled.service.
Unpacking mpd-oled (0.2+202105121736+0e64706) over (0.2+202105121736+0e64706) …
Setting up mpd-oled (0.2+202105121736+0e64706) …
Created symlink /etc/systemd/system/multi-user.target.wants/mpd_oled.service → /etc/systemd/system/mpd_oled.service.
volumio@volumio:/tmp$ chmod 755 /home/volumio/mpd_oled_volumio_install_latest.sh
chmod: cannot access ‘/home/volumio/mpd_oled_volumio_install_latest.sh’: No such file or directory
volumio@volumio:/tmp$ sudo bash /home/volumio/mpd_oled_volumio_install_latest.sh
bash: /home/volumio/mpd_oled_volumio_install_latest.sh: No such file or directory
pls find the error :
volumio@volumio:~$ chmod 755 mpd_oled_volumio_install_latest.sh
volumio@volumio:~$ sudo bash mpd_oled_volumio_install_latest.sh
Hit:1 Index of /debian buster InRelease
Hit:2 Index of /raspbian buster InRelease
Hit:3 https://deb.nodesource.com/node_14.x buster InRelease
12 packages can be upgraded. Run ‘apt list --upgradable’ to see them.
gdebi-core is already the newest version (0.9.5.7+nmu3).
0 upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
–2022-01-31 17:52:42-- http://pitastic.com/mpd_oled/packages/mpd_oled-0.2%2B202105121736%2B0e64706/mpd-oled_0.2%2B202105121736%2B0e64706_armhf.deb
Resolving pitastic.com (pitastic.com)… 206.189.11.143
Connecting to pitastic.com (pitastic.com)|206.189.11.143|:80… connected.
HTTP request sent, awaiting response… 304 Not Modified
File ‘mpd-oled_0.2+202105121736+0e64706_armhf.deb’ not modified on server. Omitting download.
A check is being run to look for files that indicate mpd_oled has
installed more than once and to different system locations
FOUND: mpd_oled found in /usr/bin
No conflicts found: mpd_oled is installed only in /usr
No, first copy the unzipped folder from Balbuze to your home folder
go to that folder and run volumio plugin install
When ready: volumio vrestart
When ready sudo bash mpd_oled_volumio_install_latest.sh
When ready sudo reboot
thanks a lot
this is working now . I did not realize that your script just add the missing files to plugins
I just hope that this plugin will be ported to plugins store … it is very important from my pov
Many thanks
you can try to uninstall the plugin from the plugin page.
If that is not working, I should start from a fresh flash, to avoid issues. (risk of installing un-official released plugins)
Alright, so for some reason mpd_oled keeps sending getState commands when it’s enabled, which overloads my Rpi4, eventually causing Spotify Connect streams to abruptly stop after a few minutes. The only way to prevent this from happening is to turn off the mpd_oled plugin on the Plugins page.
Not that I am aware of, it’s doing the same on my system.
Keep in mind that MPD_OLED is an unofficial plugin for V3. Since I am not using Spotify-connect I don’t have problems with it.
Maybe @Balbuze or @supercrab have suggestions
I installed balbuze’s zip for Volumio 3, but I’m getting the following error:
Edit: The plugin installs just fine, it’s only when I try to save the settings in the plugin that I get the error. And of course the screen isn’t working.
