so i just leave the ssh like that?
like kill the session to continue remove the eq folder and zip file ?
just ctrl+x
yes no problem
You may have to remove by hand though
ok got it⦠enabled from guiā¦
im sorry as im new to this text base config⦠is there any guide on this on how to set things upā¦
i just want to tame down some high freq⦠like negative few db for 14khz and 16khz⦠what eq type to use and what to put in the field?
Hi I see. This is a parametric EQ. A peaking should be ok. But, it seems you need a graphical EQ, much more easy if you donāt know what is a parametric oneā¦
It is here volumio-plugins/plugins/audio_interface/volsimpleequal10 at alsa_modular Ā· balbuze/volumio-plugins Ā· GitHub
Disable or remove the other if you donāt need it.
Is there a way to manually adjust the CamillaDSP config for different samplerates? I donāt want to use the FIR-FILTER generator in the webui, I want to make my filters āby handā, but then what happens is you have to manually change the filter to the correct samplerate.
There is a function in CamillaDSP to specify filters as āfilter_$samplerate$.dblā and then have a separate file for each rate. But I donāt know if this is compatible with the Volumio plugin. Any help?
Hi!
Just name your filter with sample rate at the end (like in demo files)
myfilter-44100.xxx
myfilter-48000.xxx
myfilter-88000.xxx
and so on
and it will switch automatically
edit : in the plugin select the lowest sample rate
Ok nice! Thanks for the info.
@balbuze Thanks for the PeppyMeter plugin and works great on latest Volumio 3.x! One request, any future plans to incorporate your PeppyMeter plugin as a screensaver similar to 2aCDs plugin?
@guyp2k
There will be some good news about it soon.
I can assure you that @2aCD is working on some new features on the screensaver work also me working on that. I already have that working with the @balbuze peppymeter plugin and alsa modularā¦still work in progress. Would be good to merge also balbuze in the way but i guess heās pretty busy with the development of some new plugins for Volumio Buster.
Best Regards
Hello. For sure we can merge all improvement. I didnāt follow exactly what has been done, but if you point me exactly what you need, I will integrate it. Or if someone else want to do it, no problems!
Hey!
Nice to hear that @balbuze !
I really hope that chance to be true for all the members and to be official plugin on Volumio Buster
@2aCD is making an awesome work and big improvements on the screensaver vumeter with infos.
So letās just wait that and then if @2aCD also wants to merge it, we can do it for all members and push commits to GitHub
I dont want to mess with your work or @2aCD work
Best Regards
Thanks @balbuze for the reply and to answer your question, using your peppymeter plugin, would it be possible to add the ability function as a screensaver instead of a permanent overlay i.e., when ever you press play/pause from an app the Volumio UI is available and once you press play, peppymeter is visible again. Lastly, if you touch the Volumio display the UI would appear and once you press play, peppymeter is engaged again.
If someone point me where to find the modified version, I would update the plugin
@balbuze See here:
Step 6: install autostart and UI integration
First problem. Updating the UI results to a non updatable system without resetting itā¦
Understoodā¦
One issue I came across I think is related to @balbuze peppymeter plugin, is if I play a file greater than 44.1/16 I receive the following error:
Error
Failed to open ALSA (alsa) faild to
open alsa device āvolumioā snd_pcm_hardware_params_set_buffer_time_near_failed() illegal argument
If I uninstall the plugin, no issues. Volumio 3.074 and HIFIBerry DAC2HD.
i cant get the pepptmeter work on my intel nuc on volumio3 buster
here is the error from Xorg.0.log
[ 35.827]
X.Org X Server 1.20.4
[ 35.827] Build Operating System: Linux 4.19.0-12-amd64 x86_64 Debian
[ 35.827] Current Operating System: Linux volumio 5.10.35 #1 SMP Fri Jan 22 21:30:44 CET 2021 x86_64
[ 35.827] Kernel command line: BOOT_IMAGE=/vmlinuz biosdevname=0 splash plymouth.ignore-serial-consoles quiet ro rootwait imgpart=UUID=57e8d8c6-13b2-47f7-9726-80ce12b1407f bootpart=UUID=D83A-828B datapart=UUID=15ab55b1-0e82-413c-aefb-4e10eabae8cf imgfile=/volumio_current.sqsh logo.nologo vt.global_cursor_default=0 acpi_backlight=vendor use_kmsg=yes net.ifnames=0 loglevel=0
[ 35.827] Build Date: 01 December 2020 05:59:57PM
[ 35.827] xorg-server 2:1.20.4-1+deb10u2 (Debian -- User Support)
[ 35.827] Current version of pixman: 0.36.0
[ 35.827] Before reporting problems, check http://wiki.x.org
[ 35.827] Markers: (ā) probed, () from config file, (==) default setting,
[ 35.827] (==) Log file: ā/home/volumio/.local/share/xorg/Xorg.0.logā, Time: Fri May 28 01:36:58 2021
[ 35.836] (==) Using system config directory ā/usr/share/X11/xorg.conf.dā
[ 35.836] (==) No Layout section. Using the first Screen section.
[ 35.836] (==) No screen section available. Using defaults.
[ 35.836] () |ā>Screen āDefault Screen Sectionā (0)
[ 35.836] (**) | |ā>Monitor āā
[ 35.836] (==) No monitor specified for screen āDefault Screen Sectionā.
[ 35.836] (==) Automatically adding devices
[ 35.836] (==) Automatically enabling devices
[ 35.836] (==) Automatically adding GPU devices
[ 35.843] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 35.843] (WW) The directory ā/usr/share/fonts/X11/cyrillicā does not exist.
[ 35.843] Entry deleted from font path.
[ 35.847] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 35.847] (==) ModulePath set to ā/usr/lib/xorg/modulesā
[ 35.847] (II) The server relies on udev to provide the list of input devices.
[ 35.847] (II) Loader magic: 0x55706b214e20
[ 35.847] (II) Module ABI versions:
[ 35.847] X.Org ANSI C Emulation: 0.4
[ 35.847] X.Org Video Driver: 24.0
[ 35.847] X.Org XInput driver : 24.1
[ 35.847] X.Org Server Extension : 10.0
[ 35.847] (EE) systemd-logind: failed to get session: PID 1071 does not belong to any known session
[ 35.848] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 35.860] (ā) PCI:*(0@0:2:0) 8086:193b:8086:2064 rev 9, Mem @ 0xdb000000/16777216, 0x90000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x???/131072
[ 35.860] (II) LoadModule: āglxā
[ 35.861] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 35.889] (II) Module glx: vendor=āX.Org Foundationā
[ 35.889] compiled for 1.20.4, module version = 1.0.0
[ 35.889] ABI class: X.Org Server Extension, version 10.0
[ 35.889] (==) Matched modesetting as autoconfigured driver 0
[ 35.889] (==) Matched fbdev as autoconfigured driver 1
[ 35.889] (==) Matched vesa as autoconfigured driver 2
[ 35.889] (==) Assigned the driver to the xf86ConfigLayout
[ 35.889] (II) LoadModule: āmodesettingā
[ 35.892] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 35.895] (II) Module modesetting: vendor=āX.Org Foundationā
[ 35.895] compiled for 1.20.4, module version = 1.20.4
[ 35.895] Module class: X.Org Video Driver
[ 35.895] ABI class: X.Org Video Driver, version 24.0
[ 35.895] (II) LoadModule: āfbdevā
[ 35.895] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 35.896] (II) Module fbdev: vendor=āX.Org Foundationā
[ 35.896] compiled for 1.20.0, module version = 0.5.0
[ 35.896] Module class: X.Org Video Driver
[ 35.896] ABI class: X.Org Video Driver, version 24.0
[ 35.896] (II) LoadModule: āvesaā
[ 35.896] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 35.899] (II) Module vesa: vendor=āX.Org Foundationā
[ 35.899] compiled for 1.20.1, module version = 2.4.0
[ 35.899] Module class: X.Org Video Driver
[ 35.899] ABI class: X.Org Video Driver, version 24.0
[ 35.899] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 35.899] (II) FBDEV: driver for framebuffer: fbdev
[ 35.899] (II) VESA: driver for VESA chipsets: vesa
[ 35.899] (EE)
Fatal server error:
[ 35.899] (EE) parse_vt_settings: Cannot open /dev/tty0 (Permission denied)
[ 35.899] (EE)
[ 35.899] (EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[ 35.899] (EE) Please also check the log file at ā/home/volumio/.local/share/xorg/Xorg.0.logā for additional information.
[ 35.899] (EE)
[ 35.900] (WW) xf86CloseConsole: KDSETMODE failed: Bad file descriptor
[ 35.900] (WW) xf86CloseConsole: VT_GETMODE failed: Bad file descriptor
[ 35.900] (EE) Server terminated with error (1). Closing log file.
Blockquote
Hi @balbuze
I tried to install the volspotconnect2 from the alsa_modular branch following the instructions given. I get an error in the service.
The status volspotconnect2.service command returns the below
ExecStart=/bin/bash /data/plugins/music_service/volspotconnect2/startconnect.sh (code=exited, status=127)
and the journalctl -f -o cat -u volspotconnect2.service returns the below
/data/plugins/music_service/volspotconnect2/startconnect.sh: line 4: ./vollibrespot: No such file or directory
The plugins UI shows the plugin as active.
I am running the volumio beta version 3.077 on my Minix Z64 and the vollibrespot-i686.tar.xz was downloaded and extracted successfully.
Please let me know if there is anyway to resolve the issue. I can help with the logs needed.
Regards
Ashok
Hello. I didnāt check but my guess is that this i686 version of vollibrespot is not Compatible with i686⦠The install.sh shouldnāt allow to install it.
