Not reading complete music labrary
Hi, Newbie to Volumio… Current set up - RaspPI 4/32Gb Class10 Card/HiFiBerry DAC2HD/PI Touchscreen and running Volumio 3.512. All working except not reading all music in library. Currently accessing Twonky Server on main W11 PC but only indexing (showing) 464 Artists/Albums out of 857. Have tried Rescan/Update no change.
I think I did get an error message flash up on 1st setup - but as this was all new to me I didn’t understand the message.
I have an old Naim streamer/DAC and this accesses the same Twonky server and displays all the library.
Help…!!! What can I do to get Volumio to see the whole library…???
Regards, Rod
Please run a disk check on the disk that host your music files and post a log when there are still scanning issues.
Have run Chkdsk on W11 disk storing music - Windows reports ‘No Issues’
Still scanning issues only loading approx half my library - choosing Artist/Album only loads ‘A’ to ‘M’ - nothing appears after artist beginning ‘M’.
Have run log and here is the link:
http://logs.volumio.org/volumio/a6BQzPe.html
Best regards,
Rod Cox
This log doesn’t hold any logging of scanning music, however it does shows that it doesn’t mount your NAS.
volumio : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/mount -t nfs -o ro,soft,noauto 192.168.1.10:\\STUDY-2\Study - Ent\Music /mnt/NAS/Study_Music
Thanks - I tried NAS but couldn’t get connect to NAS working…!!
So, I connected via the Media Servers option which saw my Twonky DLNA server and this connected and is sort of working - this is only showing about half of my library.
I use the same Twonky server to connect a Naim server/dac and this works fine…
Should Volumio work using Twonky server connection?
Regards,
Rod
Many thanks for the pointers… I have now (after hours of trying) got the NAS mounted and the all the music is now showing and all is working.
As per my previuous response should Volumio work connecting via the Twonky server?
Best regards,
Rod
