Not able to boot Volumio 3.378 on Raspberry
Hi all,
I burned the Volumeio image on a Raspberry 4 but once I try to boot it I receive the following message. Tried a couple of times to remake the SD card but no success.
Image used: https://updates.volumio.org/pi/volumio/3.378/Volumio-3.378-2022-09-30-pi.zip
Thanks in advance for your help,
Looks like something went wrong with flashing.
2 things 2 check/do::
  • Flash the image using Raspberry Pi Imager or Win32DiskImager
  • Replace your SD card
Balena Etcher was the problem then, it worked with Raspberry Pi Imager.
thanks again
Thanks for reporting back
