From the logs the Pi is trying to initiate AP which is bogus. I assume that you have wpa_supplicant.conf with your wifi settings.
I wonder the output from:
sudo vcgencmd get_config int
sudo vcgencmd measure_volts
grajek kernel: brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430b0-sdio for chip BCM43430/2
aphy_params_current=819
arm_freq=1000
arm_freq_min=600
audio_pwm_mode=514
camera_auto_detect=-1
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x331df0
disable_commandline_tags=2
disable_fw_kms_setup=-1
disable_l2cache=1
disable_splash=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
dphy_params_current=547
dvfs=3
enable_tvout=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_enable_4kp60=-1
ignore_lcd=1
init_uart_clock=0x2dc6c00
max_framebuffers=-1
over_voltage_avs=6250
pause_burst_frames=1
pciex4_reset=1
program_serial_random=1
ramfsaddr=-1
sdram_freq=450
total_mem=512
hdmi_force_cec_address:0=65535
hdmi_force_cec_address:1=65535
hdmi_force_hotplug:0=1
hdmi_pixel_freq_limit:0=0x9a7ec80
hdmi_pixel_freq_limit:1=0x9a7ec80
volt=1.2563V
cat /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=/var/run/wpa_supplicant
network={
scan_ssid=1
ssid=“XXXXXXXX”
psk=0000xxxxx
priority=2
All previous versions of volumio works without any problems. Even last version 3.569 works ok, wifi starts normally with system startup. After upgrade to 3.601 there is no wifi, only external usb ethernet adapter works ok.
@ms4sman or anyone else, should you have a usb-to-eth adapter at hand, could you try a log?
I see @dgcracker has one, that would be helpful.
Can you check the firmware date:
sudo dmesg | grep brcmf
Line like this one:
brcmf_c_preinit_dcmds: Firmware: BCMxxxx/x wl0:
[ 25.751456] brcmfmac: F1 signature read @0x18000000=0x1542a9a6
[ 25.762045] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43430b0-sdio for chip BCM43430/2
[ 25.764580] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430b0-sdio.raspberrypi,model-zero-2-w.bin failed with error -2
[ 25.764922] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43430b0-sdio.bin failed with error -2
[ 25.771347] usbcore: registered new interface driver brcmfmac
[ 26.772322] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
Which log do you need? I have a usb to eth adapter.
This is interesting.
Can you add to the /boot/cmdline.txt before rootwait additional over_voltage=2 and reboot?
This is actually failing on device wait.
yes, found that one too, we are discussing this. This would be the main issue.
problem found and fixed
you can enable test mode and update to the beta v3.607, or flash the image
https://updates.volumio.org/pi/volumio/3.607/Volumio-3.607-2024-01-30-pi.zip
I have upgraded from 3.601 to beta v3.607 and WiFi is back
Thank you for help!
thank you too! you pointed us into the right direction with your indications, then it was easy to identify and fix the problem
I will give this a test later tonight when I have time. Thanks for the quick work finding and fixing it!
