No USB drive and SSH will not login
I am having two problems after powering my Volumio on Pi4 down while being away.
  1. Volumio no longer sees has the USB which contains my local music. It still shown the music from the database, but when selected the music does not play.
  2. Volumio will play music from YouTube stream
  3. I went to open a SSH window to look, but cannot login as it gets stuck after entering the password, so cannot get a terminal window open.
Any suggestion welcome, as the only action I can thing of is a full re install, as I assume my install has been corrupted during the power down.
you can try to un and re-plug the USB drive while Volumio is running.
Did you power down via GUI or just pulled the plug?
