hello
today i installed the latest update of volumio, after the update, i cant see my personal playlist
the rest of spotify works, i deleted the plugin,and re-installed it again, but nothing seems to work.
doe i have to do something?
hello
Have a look here.
Thank you.
do i have to log in with putty or do i have to remove the sdcard?
You can do either to transfer the file, but since you need to use ssh anyway to complete the procedure, it would make sense to use putty/SCP.
