No sound.
Hello guys
A newbie needs help!
I have iOS app installed, Spotify connect 2 plugin installed, webUI shown active.
I have also an Spotify app installed before Volumio app was.
On Volumio app, at installed plugins, it shows a red dot next to the Spotify connect 2 and of course the bar under it showed disabled.
I tried to enable it and after out and in, it came back to disable. I can’t find Spotfy line in the browse, either.
I can played my files(shown also playing on the Volumio webUI but Voumio app shows nothing) on the phone but no output sound.
I tried redo above twice but nothing changed.
Does anybody have any idea? Your help is very much appreciated.
I have another app which is a Yamaha device app on the phone. It also connects to Spotify app if I turn it on.( not when I was working with the Volumio) Would that be the reason?
Forget the apps and plugins for the moment … do you have a working Volumio player simply accessed by a browser running local content or a web radio station?
chsims1 Thanks to your reply.
Yes. My local USB files were run by Volumio player well through a browser for 2 days.
I found spotify works with win 10 on surface pro 4. It is still not working on iPhone X.
I am sorry. I found it is working on the phone. Problem is too low volume on the iPhone.
Volume isn’t adjustable on the phone through MusicCast app(previous app for spotify).
That’s why I didn’t try it on the Volumio.
