No sound with equalizer plugin & Spotify connect 2
Hi all,
I am facing a new issue.
I am using a Raspberry 2 + DAC Allo Boss - fresh install V2.526.
Everything is fine. But I want to add 2 plugins : Spotify connect & the equalizer. Great features but also big issue… that makes me desapointed. I hope that you will be able to help me.
I made many test and here here are the issues :
  • When I install spotify connect 2 only, everything is fine, I can use DLNA, shared folder, spotify & airplay. Great.
  • When I add the equalizer plugin, the problems starts, I lost the spotify connection. But air & shared folder are working. A reboot will result on nothing is working. I had to factory reset Volumio.
I try to install equalizer first & add spotify later, same issue.
Equalizer alone is OK, Spotify alone is OK, both do not work
Both features are great, thanks for your help !
Some problem.
I add, if you cange Audio exit from jack through equalizer plugin to jack it sounds but not equalized.
