No more Volumio for Sparky?
Many thanks for your efforts! We really appreciate that!
Just tried the 2.882 image on my old Sparky and it worked like a charm. I did get a rpi 4 as a backup, just in case, but a million thanks for the work, appreciate that. I hate throwing things away, and this has prolonged the useful life of my sparky for a bit!
Installed the 2.882 image and Tidal connect works fine.
Dear Volumio Team !
Please kindly take into consideration future support for Sparky sweethearts - as they are in my and not only mine opinion the best sounding simple SBC !
Thank you such much for great job which you make !
Adam
Thank you for 2.882. I created an account just to come and say that I appreciate your efforts. It works well with my Sparky/Usbridge. I know there are not many Sparky users, so understand your decision to drop it, but can I please request that you still make availabe “Totally untested, Only for the braves” versions of major future releases. Thanks!
Dear Sparky Users !
Recently I found my Sparky was able to update into 2.916 version simple by clicking “Check for updates” :slight_smile:
Do you have the same with your ones ?
@volumio - can you provide us a link for this version ?
Thank you !
volumio-2.916-2021-10-01-sparky
I don’t normally publish V2 versions, but make an exception for Sparky as it has been discontinued anyway. There is no V3.
Dear all,
Can anyone please share a working link for Volumio download for Sparky. I tried the above mentioned links , but clicking or copying link address gives “error 404”. Please help me in resurrecting old sparky. Thanks
The latest posted by Gé is working.
