Am using Volumio on Allo USBridge. Seems to work fine for a few months and then disconnected for 3 weeks due to biz trip. Came back and reconnect but unable to connect and when i type ifconfig, no ip address. Just “UP BROADCAST RUNNING MULTICAST”…No idea what this means.
The usbridge is connected to a Cisco switch. Two other connections to the same switch worked but not the usbridge. When I connect the usbridge to a router, I was able to connect. No idea why no ip address when connected to switch when the other two connections (to the same switch) are able to connect.
Any assistance is much appreciated as this is getting rather frustrating. Thanks in advance.
