No internet radio or MP3 NAS playback after updating to version 4.103
I am unable to play any webradio or MP3 audio via NAS using the latest version 4.103 . I am using a HifiBerry DAC+ pro . No issue playing wav files
Add to this my main system now playing up . At 10pm last night , it rebooted , wiped everything and I was faced with a fresh install where the sub output of my Allo Piano 2.1 stopped working . It was an old version of Volumio . Put the new 4.103 version on there which restored the sub out but now facing the same issue playing MP3 and web radio . Help !
To get support we need info.
Help request guidelines
Log retrieval instructions
Thank you , have submitted the log . MP3 NAS playback now seems to be restored by toggling audio resampling on the main system with Allo Piano 2.1 DAC
You need to copy the url here :slight_smile:
Apologies . here is the url
http://logs.volumio.org/volumio/uEDI9bn.html
I have two setups , both running the latest version of Volumio . One uses Allo Piano 2.1 DAC , the other a Hifiberry DAC+pro . Both have the same issue , there were no problems using older versions of Volumio . When I open an internet radio station , there is no audio and the counter stops at 2 seconds . Any ideas how this issue can be rectified ? I am unable to stream internet radio , which is what I tend to listen to . Now at desperation point . Help !
Now solved ! Changed the radio URL from https to http and now working .
