No hot spot for set up
flashed a pi4 have a touch screen, turn it on volumio screen shows then disappears and I cannot find a hot spot to set up, tried phone with app and pc, lost don’t know what to do, I have flashed it twice and tried everything I know
Make sure you …
  • download the image from Volumio
  • Unzip it
  • Use only Raspberry Pi Imager to flash it with no pre-configured settings
Thank you, I did fill in the settings I’ll try that.
If you haven’t gotten it to work, try Balena instead. I went through dozens of failed fresh installation attempts on a Pi 4, Pi 400, Pi 5 and x86 until I went back to Balena
I got so frustrated I bought a Wiim ultra and it works thank you.
Totally understand. I have a Wiim Pro I absolutely love. The one thing that keeps me with Volumio is the ability to display the “Now Playing” screens on large displays and the Peppy Meters on my small screens.
But it’s only a matter of time before the other folks incorporate those features. Some of the newer components have the VU meter options.
