No audio with equalizer after reboot
Hi everyone!
I have a problem with setting up my volumio “wine box speaker”.
I have a volumio last version running on a raspberry Pi Zero W with external usb wireless card and a KKmoon DAC Sabre ES9023 I2S connected to it.
Audio output is set to HiFiBerry DAC and i can cearly hear the audio coming out from the speaker.
Than i activate the last version of the equalizer plugin. Again, audio output works fine and also i can hear the regulations i make on the equalizer.
But, after reboot, audio output no longer works. So I have to de-activate equalizer plugin, re-set the I2S DAC and then reboot to be able to hear again audio from the speaker.
Can anyone help me with this issue?
Tnx
@balbuze, any idea on what to do or to check?
I’ll try to check tonight with a similar configuration. Do you use a dev version of volumio?
thank you very much!
I use the one available into the plugin section of volumio, with automatic installation.
ok for the plugin but what about volumio ? dev or official version ?
Volumio is in official version: 2.389
