Same result - The display remains blank and I still get the xserver error.
Yes, â99-fbturbo.confâ should not be required for a screen connected via HDMI, but I wanted to make sure that the absence of the file is not the cause after all. I think you can delete it again:
sudo rm /usr/share/X11/xorg.conf.d/99-fbturbo.conf
What you could try next is adding
hdmi_group=2
hdmi_mode=87
hdmi_cvt 1920 1080 60 3
hdmi_drive=2
to â/boot/userconfig.txtâ and reboot. But the fact that the screen previously worked without this setting does not necessarily suggest that this change will helpâŚ
You are correct, that didnât help.
The expected framebuffer device âfb0â is not present in â/devâ. This is the reason for the error message. Currently I am running out of ideas why this happens after a reboot⌠For now I suggest to uninstall and re-install the plugin and if the screen should work, post the result of
cat /var/log/Xorg.0.log
again.
I have reinstalled the plugin and it worked for a while. At some point, I started the system without the monitor connected via HDMI and that broke the plugin, again requiring it to be reinstalled. Here is the log file while everything is working:
volumio@volumio1:~$ cat /var/log/Xorg.0.log
[ 73.480]
X.Org X Server 1.20.4
[ 73.480] Build Operating System: Linux 5.4.0-72-generic armv8l Raspbian
[ 73.480] Current Operating System: Linux volumio1 5.10.92-v7+ #1514 SMP Mon Jan 17 17:36:39 GMT 2022 armv7l
[ 73.480] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=1016 bcm2708_fb.fbheight=1856 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 splash plymouth.ignore-serial-consoles dwc_otg.fiq_enable=1 dwc_otg.fiq_fsm_enable=1 dwc_otg.fiq_fsm_mask=0xF dwc_otg.nak_holdoff=1 quiet console=ttyS0,115200 console=tty1 imgpart=/dev/mmcblk0p2 imgfile=/volumio_current.sqsh rootwait bootdelay=5 elevator=noop logo.nologo vt.global_cursor_default=0 net.ifnames=0 snd-bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 loglevel=0
[ 73.480] Build Date: 04 January 2022 10:05:34AM
[ 73.480] xorg-server 2:1.20.4-1+rpt4+deb10u4 (Debian -- Support)
[ 73.480] Current version of pixman: 0.36.0
[ 73.480] Before reporting problems, check http://wiki.x.org
[ 73.480] Markers: (â) probed, () from config file, (==) default setting,
[ 73.481] (==) Log file: â/var/log/Xorg.0.logâ, Time: Mon Mar 14 13:40:39 2022
[ 73.494] (==) Using config directory: â/etc/X11/xorg.conf.dâ
[ 73.495] (==) Using system config directory â/usr/share/X11/xorg.conf.dâ
[ 73.504] (==) No Layout section. Using the first Screen section.
[ 73.504] (==) No screen section available. Using defaults.
[ 73.504] () |â>Screen âDefault Screen Sectionâ (0)
[ 73.504] (**) | |â>Monitor ââ
[ 73.512] (==) No monitor specified for screen âDefault Screen Sectionâ.
[ 73.512] (==) Automatically adding devices
[ 73.512] (==) Automatically enabling devices
[ 73.512] (==) Automatically adding GPU devices
[ 73.518] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 73.519] (WW) The directory â/usr/share/fonts/X11/cyrillicâ does not exist.
[ 73.519] Entry deleted from font path.
[ 73.521] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
[ 73.521] (==) ModulePath set to â/usr/lib/xorg/modulesâ
[ 73.521] (II) The server relies on udev to provide the list of input devices.
[ 73.521] (II) Loader magic: 0x1fdf80
[ 73.521] (II) Module ABI versions:
[ 73.521] X.Org ANSI C Emulation: 0.4
[ 73.521] X.Org Video Driver: 24.0
[ 73.521] X.Org XInput driver : 24.1
[ 73.521] X.Org Server Extension : 10.0
[ 73.530] (â) using VT number 2
[ 73.530] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 73.531] (II) no primary bus or device found
[ 73.531] (II) LoadModule: âglxâ
[ 73.536] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 73.613] (II) Module glx: vendor=âX.Org Foundationâ
[ 73.613] compiled for 1.20.4, module version = 1.0.0
[ 73.613] ABI class: X.Org Server Extension, version 10.0
[ 73.613] (==) Matched modesetting as autoconfigured driver 0
[ 73.613] (==) Matched fbdev as autoconfigured driver 1
[ 73.613] (==) Assigned the driver to the xf86ConfigLayout
[ 73.613] (II) LoadModule: âmodesettingâ
[ 73.616] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 73.621] (II) Module modesetting: vendor=âX.Org Foundationâ
[ 73.622] compiled for 1.20.4, module version = 1.20.4
[ 73.622] Module class: X.Org Video Driver
[ 73.622] ABI class: X.Org Video Driver, version 24.0
[ 73.622] (II) LoadModule: âfbdevâ
[ 73.622] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 73.627] (II) Module fbdev: vendor=âX.Org Foundationâ
[ 73.627] compiled for 1.20.3, module version = 0.5.0
[ 73.627] Module class: X.Org Video Driver
[ 73.627] ABI class: X.Org Video Driver, version 24.0
[ 73.627] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 73.627] (II) FBDEV: driver for framebuffer: fbdev
[ 73.697] (WW) Falling back to old probe method for modesetting
[ 73.698] (EE) open /dev/dri/card0: No such file or directory
[ 73.698] (WW) Falling back to old probe method for fbdev
[ 73.698] (II) Loading sub module âfbdevhwâ
[ 73.698] (II) LoadModule: âfbdevhwâ
[ 73.698] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 73.706] (II) Module fbdevhw: vendor=âX.Org Foundationâ
[ 73.706] compiled for 1.20.4, module version = 0.0.2
[ 73.706] ABI class: X.Org Video Driver, version 24.0
[ 73.707] (II) FBDEV(0): using default device
[ 73.707] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 73.708] (II) FBDEV(0): Creating default Display subsection in Screen section
âDefault Screen Sectionâ for depth/fbbpp 24/32
[ 73.708] (==) FBDEV(0): Depth 24, (==) framebuffer bpp 32
[ 73.708] (==) FBDEV(0): RGB weight 888
[ 73.708] (==) FBDEV(0): Default visual is TrueColor
[ 73.708] (==) FBDEV(0): Using gamma correction (1.0, 1.0, 1.0)
[ 73.708] (II) FBDEV(0): hardware: BCM2708 FB (video memory: 7424kB)
[ 73.708] (DB) xf86MergeOutputClassOptions unsupported bus type 0
[ 73.708] (II) FBDEV(0): checking modes against framebuffer deviceâŚ
[ 73.708] (II) FBDEV(0): checking modes against monitorâŚ
[ 73.708] (II) FBDEV(0): Virtual size is 1016x1856 (pitch 1016)
[ 73.708] () FBDEV(0): Built-in mode âcurrentâ
[ 73.708] (==) FBDEV(0): DPI set to (96, 96)
[ 73.708] (II) Loading sub module âfbâ
[ 73.708] (II) LoadModule: âfbâ
[ 73.709] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 73.717] (II) Module fb: vendor=âX.Org Foundationâ
[ 73.717] compiled for 1.20.4, module version = 1.0.0
[ 73.717] ABI class: X.Org ANSI C Emulation, version 0.4
[ 73.717] () FBDEV(0): using shadow framebuffer
[ 73.717] (II) Loading sub module âshadowâ
[ 73.717] (II) LoadModule: âshadowâ
[ 73.718] (II) Loading /usr/lib/xorg/modules/libshadow.so
[ 73.722] (II) Module shadow: vendor=âX.Org Foundationâ
[ 73.722] compiled for 1.20.4, module version = 1.1.0
[ 73.722] ABI class: X.Org ANSI C Emulation, version 0.4
[ 73.722] (II) UnloadModule: âmodesettingâ
[ 73.722] (II) Unloading modesetting
[ 73.770] (==) FBDEV(0): Backing store enabled
[ 73.776] (==) FBDEV(0): DPMS enabled
[ 73.778] (II) Initializing extension Generic Event Extension
[ 73.779] (II) Initializing extension SHAPE
[ 73.779] (II) Initializing extension MIT-SHM
[ 73.780] (II) Initializing extension XInputExtension
[ 73.785] (II) Initializing extension XTEST
[ 73.786] (II) Initializing extension BIG-REQUESTS
[ 73.787] (II) Initializing extension SYNC
[ 73.787] (II) Initializing extension XKEYBOARD
[ 73.788] (II) Initializing extension XC-MISC
[ 73.789] (II) Initializing extension SECURITY
[ 73.790] (II) Initializing extension XFIXES
[ 73.791] (II) Initializing extension RENDER
[ 73.792] (II) Initializing extension RANDR
[ 73.794] (II) Initializing extension COMPOSITE
[ 73.802] (II) Initializing extension DAMAGE
[ 73.803] (II) Initializing extension MIT-SCREEN-SAVER
[ 73.804] (II) Initializing extension DOUBLE-BUFFER
[ 73.805] (II) Initializing extension RECORD
[ 73.806] (II) Initializing extension DPMS
[ 73.807] (II) Initializing extension Present
[ 73.808] (II) Initializing extension DRI3
[ 73.809] (II) Initializing extension X-Resource
[ 73.809] (II) Initializing extension XVideo
[ 73.820] (II) Initializing extension XVideo-MotionCompensation
[ 73.820] (II) Initializing extension SELinux
[ 73.820] (II) SELinux: Disabled on system
[ 73.820] (II) Initializing extension GLX
[ 73.821] (II) AIGLX: Screen 0 is not DRI2 capable
[ 75.379] (II) IGLX: Loaded and initialized swrast
[ 75.379] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 75.379] (II) Initializing extension XFree86-VidModeExtension
[ 75.380] (II) Initializing extension XFree86-DGA
[ 75.381] (II) Initializing extension XFree86-DRI
[ 75.384] (II) Initializing extension DRI2
[ 75.710] (II) config/udev: Adding input device TSTP MTouch (/dev/input/event0)
[ 75.710] () TSTP MTouch: Applying InputClass âlibinput pointer catchallâ
[ 75.710] (II) LoadModule: âlibinputâ
[ 75.711] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 75.748] (II) Module libinput: vendor=âX.Org Foundationâ
[ 75.749] compiled for 1.20.3, module version = 0.28.2
[ 75.749] Module class: X.Org XInput Driver
[ 75.749] ABI class: X.Org XInput driver, version 24.1
[ 75.749] (II) Using input driver âlibinputâ for âTSTP MTouchâ
[ 75.749] () TSTP MTouch: always reports core events
[ 75.749] () Option âDeviceâ â/dev/input/event0â
[ 75.749] () Option â_sourceâ âserver/udevâ
[ 75.792] (II) event0 - TSTP MTouch: is tagged by udev as: Mouse
[ 75.793] (II) event0 - TSTP MTouch: device is a pointer
[ 75.793] (II) event0 - TSTP MTouch: device removed
[ 75.831] () Option âconfig_infoâ âudev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.0/0003:0416:C168.0001/input/input0/event0â
[ 75.831] (II) XINPUT: Adding extended input device âTSTP MTouchâ (type: MOUSE, id 6)
[ 75.832] () Option âAccelerationSchemeâ ânoneâ
[ 75.832] () TSTP MTouch: (accel) selected scheme none/0
[ 75.832] () TSTP MTouch: (accel) acceleration factor: 2.000
[ 75.832] () TSTP MTouch: (accel) acceleration threshold: 4
[ 75.843] (II) event0 - TSTP MTouch: is tagged by udev as: Mouse
[ 75.843] (II) event0 - TSTP MTouch: device is a pointer
[ 75.847] (II) config/udev: Adding input device TSTP MTouch (/dev/input/mouse0)
[ 75.847] (II) No input driver specified, ignoring this device.
[ 75.847] (II) This device may have been added with another device file.
[ 75.851] (II) config/udev: Adding input device TSTP MTouch (/dev/input/event1)
[ 75.852] () TSTP MTouch: Applying InputClass âlibinput touchscreen catchallâ
[ 75.852] () TSTP MTouch: Applying InputClass âTouch rotationâ
[ 75.852] (II) Using input driver âlibinputâ for âTSTP MTouchâ
[ 75.852] () TSTP MTouch: always reports core events
[ 75.852] () Option âDeviceâ â/dev/input/event1â
[ 75.852] () Option â_sourceâ âserver/udevâ
[ 75.861] (II) event1 - TSTP MTouch: is tagged by udev as: Touchscreen
[ 75.862] (II) event1 - TSTP MTouch: device is a touch device
[ 75.863] (II) event1 - TSTP MTouch: device removed
[ 75.910] () Option âconfig_infoâ âudev:/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3:1.1/0003:0416:C168.0002/input/input2/event1â
[ 75.910] (II) XINPUT: Adding extended input device âTSTP MTouchâ (type: TOUCHSCREEN, id 7)
[ 75.910] () Option âAccelerationSchemeâ ânoneâ
[ 75.910] () TSTP MTouch: (accel) selected scheme none/0
[ 75.910] () TSTP MTouch: (accel) acceleration factor: 2.000
[ 75.910] () TSTP MTouch: (accel) acceleration threshold: 4
[ 75.910] () Option âTransformationMatrixâ â0 1 0 -1 0 1 0 0 1â
[ 75.920] (II) event1 - TSTP MTouch: is tagged by udev as: Touchscreen
[ 75.920] (II) event1 - TSTP MTouch: device is a touch device
[ 75.924] (II) config/udev: Adding input device TSTP MTouch (/dev/input/mouse1)
[ 75.924] (II) No input driver specified, ignoring this device.
[ 75.925] (II) This device may have been added with another device file.
Was this also the constellation when the problem occurred at the earlier time?
What is your Pi model?
No, but the screen is slow to start up. I am starting to wonder if the screen is starting too late and that is resulting in a similar condition. Iâll do some more testing.
I have a Pi3 B+
Hm, âhdmi_force_hotplug=1â in â/boot/config.txtâ should take care of that IMHO. This option should make the Pi recognize an HDMI monitor that has not already been connected on boot, but gets plugged in / powered later on.
Do you have another HDMI monitor you could use for testing?
Please, when post a log ,use ``` in the line above your past to make it readble. Thanks
I have done some more testing and hereâs what I found:
I use the touch monitor rotated to 90 degrees. It works fine initially, but after 2-3 power cycles of the PI and monitor, the monitor will fail to display the image and I will get the xserver error.
If I rotate the screen back to 0 degrees using the plugin settings, the monitor comes up as expected, but if I rotate back to 90, it will not work, even after complete reboots.
If I reboot with a standard monitor, it works with either orientation.
If I boot with the standard monitor at 90 degrees and then switch the cable to the touch monitor, it will work.
The touch monitor will not work from boot at 90 degrees until I remove and reinstall the plugin.
Thatâs weird.
Yeah, I thought so too. And I hate to be the guy who comes up with the weird ones. Let me know if thereâs any other info I can gather that might help to sort this out.
You can check if it helps to increase the GPU memory to, e.g. 64 MB on the pluginâs configuration page.
Iâm at 100MB
Ok, coming from your earlier post I was assuming you were on 32MB
Maybe try some other settings in â/boot/userconfig.txtâ, e.g.
hdmi_group=2
hdmi_mode=82
or
hdmi_group=1
hdmi_mode=16
One option to check could also be
hdmi_safe=1
which makes the Pi boot with maximum HDMI compatibility.
Group and mode didnât seem to have any effect, but hdmi_safe=1 did. With this setting, the display comes up, but the resolution is 640x480 even if I use group and mode. Are there any other methods to force resolution?
If you use âhdmi_safe=1â, other hdmi settings have no effect of course, since its purpose is to enforce the âsafestâ values for HDMI.
Assuming that the suggested âhdmi_groupâ and âhdmi_modeâ settings (without using âhdmi_safe=1â at the same time) did not solve the issue, can you confirm, that the problem disappears when âhdmi_safe=1â is set?
If so, I suggest to try the âhdmi_groupâ and âhdmi_modeâ settings from my previous post again but now together with âhdmi_ignore_edid=0xa5000080â, like:
hdmi_group=2
hdmi_mode=82
So it appears that using safe=1 allows the display to come up, but the resolution is 640x480.
I just noticed that gpu_mem in config.txt was set to 32 even though it is set to 100 in the plugin settings. I already know that 32 is too low. I changed and applied the GPU setting a few times, but config.txt always showed 32, so I forced it to 64 in both places and removed all of the HDMI settings that Iâve added and the monitor started working again. I rebooted a few times and it is working for the moment.
Now that it is working, I canât test your last hdmi suggestion, but I will continue trying to force the issue and Iâll use your settings if I get the opportunity.
The plugin should set the GPU memory if you change the value to something other than 32MB on the pluginâs config page. Could you please check if that happens and post the content of your current â/boot/config.txtâ?
