My setup is
Raspberry Pi 3 B+/Allo Kali/Allo Piano 2.1/1TB USB hard drive. 2000 Albums. 19,000 tracks.
Volumio is 2.389 (I tried the dev version as well, no difference, I think it is me and not Volumio)
The USB hard drive is the biggest problem for me, I get the little chime startup and everything is great except no hard drive is visible in My Music, or the USB list. (I also don’t see “Internal” or “NAS”).
Physically unplugging and replugging in sometimes gets it back but I SSH in and issue a “lazy unmount” then immediately followed by a mount.
disk wise it seems healthy: sudo fdisk -l reveals it as /dev/sda1 and 931GB (which is about right) and formatted as HTPS/NTFS/exFAT
sudo umount -l /dev/sda1
sudo mount /dev/sda1 /mnt/USB/Music/
…and that works but it does not persist. Listening to music is fine then the next day I cannot log in via the web or via SSH and I have to repeat the cycle and if I leave volumio alone for any short period of time I lose the hard drive, if I restart the player (such as switching between EQ plugin and no EQ) I lose the hard drive. It remains mounted but I have to umount it then mount it as above and then rescan. Its getting pretty tiresome
Any thoughts? I have tested the hard drive on a PC for errors between these lazy unmounts and hot plugging a USB drive is never a great idea but no errors have been found.
When it works it sounds fantastic, but I would like a library to persist and have the library available like you guys.
x
Claire
