Thanks so much for the Allo Piano fix, I could update the system after first resetting to factory settings with volumio updater
(first factory
and then forceupdate
Unfortunately, that caused problems with WiFi (I have a USB dongle ). I spent my Saturday trying to solve it, but to no avail - until I decided to connect to the 5G WiFi, which did work.
I think that the root cause of the problem with the 2.4G network is an error or warning in the logs that 80 MHz is not supported, disabling VHT. The router/AP then rejects the connection using the message:
CTRL-EVENT-AUTH-REJECT auth_type=0 auth_transaction=2 status_code=33 ie= "dd090010180203009c0000"
(Unfortunately with reboots etc. the original logs are gone, but this information still lived in my browser search logs ;-).)
May other people have a similar problem, then what helped for me (eventually), in decreasing likelihood of it actually really affecting the mode of working of the Volumio:
- connect to the 5G AP instead of the 2.4G access point
- add
country=NL
to/etc/wpa_supplicant/wpa_supplicant.conf
- remove the lines in
/etc/network/interfaces
that refer towlan0
- disable the internal WiFi using
dtoverlay=disable-wifi
in/boot/userconfig.txt
- disable the internal Bluetooth using
dtoverlay=disable-bt
For the Volumio maintainers the question whether /etc/network/interfaces
should be there at all - it seems to cause problems for the working of dhcpcd
and it should be the one or the other?
To ensure not using IPv6, I added the following two lines to /etc/dhcpcd.conf
noipv6rs
noipv6
Hope it helps somebody getting the same errors, or related WiFi problems!
For testing, I ssh
in using ethernet, using wpa_supplicant -Dnl80211 -iwlan0 -ctest.cfg
using a local test.cfg
that I edited with all options I could try, until the Volumio would finally connect to the WiFi.
