I’m a long time user of PiMusicbox…Nice but I feel there may be some issues as to how it handles the Allo Boss so I thought I’d give Volumio a try. I’ve been playing with it for a few days without success (Boss remains silent) and I can only access the UI via volumio and not IP, Anyway decided to try the Beta and everything just worked straight away except for the ability to add a network drive. The drive is connected via usb to my Gargoyle router and is accessible from Windows explorer and PIMusicbox at //192.168../Data/MUSIC a scan in Myvolumio shows /GARGOYLE/Data and no matter how I try to configure the fields I get an error (which disappears before I get chance to read it.) I Would be grateful for any pointers as to how this is handled in Volumio.
‘vers=1.0’ worked straight away, unfortunately the other problem has shown up again, the system has been left running since yesterday, just tried to play a few tracks and no output from the Boss tried disabling I2s, reboot, enable, reboot, a few times…Still nothing.
Sorry for the delayed reply I’ve been trying to find out what the problem is…Seems you were right again it’s a hardware fault (amp), Just my luck that it was cutting out only when I was trying to use Volumio, anyway it’s dead now with whatever I throw at it, Time for an upgrade I think.
Thanks very much for your help and hopefully everything will work fine when I replace the offending item.
