I downloaded the version from the download page for my Pi3, and it is nice. I have a few Pi B+ units with DACs on them and am interested in some of the features of Volumio (multi room). How do I get a version of Volumio for a B+, arm-v6 (isn’t Pi Zero the same architecture?). It is clear that the version I have on my Pi3 is for arm v7 I did not try to boot it on my B+, but am pretty sure it will not.
also, where in the UI do I find which verison it is that I am running?
The image provided is for all RPi versions. If you look under /boot/ you’ll see 2 Kernel img one for original RPi’s with arm v6 the other for arm v7, RPi 2 & 3. The boot sequence chooses the apropriate Kernel to load so you can easily swap SD Card between different RPi boards if needed.
