NAS not mounting WD
Checked syntax and path name - all correct. Sonos can access the NAS and play music. MAC can rip a cd and send it to the NAS. So I am pretty sure that side of it is working.
Tried omitting and adding / . No joy.
Any ideas?
After mount fail, the path is listed as \192.XXXXXX/Public\My Music Folder
I am a bit concerned about the / before Public. I didn’t put the / in, and it doesn’t look right?
NFS permission is set and the box itself is a Western Digital.
I just don’t remember having this problem last time I set it up.
One other thing - when I choose add a new drive, a scan is made and it just finds my BT Hub. Is this correct?
Can you post the exact error message in full please.
Error in adding network drive
exec error Error: Command
failed:usr/bin//sdo/bin/mount-t nfs-o
ro, soft,nauto
‘192.X.XXX.X.XX://mynas/Public/my music’
‘/mnt/NAS/mynas’
Mount.nfs:access denied by server while mounting
192.XXX.X.XX://mynas/Public/my music
However, I now have it working.
I was deleting the drive each time and trying again. On one attempt, I didn’t delete the drive that failed to mount. I added another. Same path, but this time the ?/\ did not appear in the text after the mount failed. Just a single / after the IP address. Then I changed from NFS back to Cif, and the drive mounted.
Deleted the first drive and re-named the second alias. All working well.
