NAS drive disappeared
I installed volumio 3.887 on a sd card for my pi zero w.
I added the Music folder from my NAS drive, and all was well. the next day I wanted to add more music to volumio from my NAS drive, but as soon as I clicked on Update, the NAS drive became unmounted, and I can’t remove it to re add it.
Well i did add a new drive but that wasn’t mounted either.
What is going on!!
You might have turned the pi Off, while the library was not ready.
You can reboot, which mostly solves the problem.
Thanks but it was play music from a radio station at the time. I have restarted volumio , and now the NAS drive is back as mounted.
That’s the situation I’m seeing ( Rivo). Though I’m rescanning and all is well.
Just got back from a two week trip and it had lost connection to my NAS.
Will try to remember to reboot to see if this resoves
Shouldn’t have to do this though
This has happened to me a few times too.
Main volumio has a USB drive with the music
Second volumio connects to the NAS share on the first, works fine
Then occasionally it just disappears
Restart of the second volumio and rescan fixes it.
Yes it did come back after I restarted Volumio, thanks
