Naim Dac compatibility
I have a naim Dac V1 which has a usb input.
On volumio X86 it works flawlessly, Normal, HD and DSD all work perfectly
On volumio Pi DSD does not work it sounds all messed up, like buzzing bees trying to sing the music.
Is there anythingI can do about this?
What Pi do you use? The Pi together with USB doesn’t always work well. The latest Pi 3B+ has improved USB capabilities, that might help.
Also there is a problem in the current kernel with correct 24bit playback, take a look there as well.
Verzonden vanaf mijn iPhone met Tapatalk
Hi in a hopes to fix it I did get the latest pi, but no dice.
