I was about to post details of my project but I do not seem to be able to put up more then one picture ( 600x450 jpg )
What should I be doing to put up multiple pictures?
As far as I can see you choose ‘upload attachment’ then choose file, hit add file, then choose upload attachment again and repeat the process
Hi
Ok thanks for that.
I was trying to attach multiple files in the same way as I do with e-mail attachments which did not work. I will get my post up there today
I suggest to use imgur: imgur.com/upload
You upload your images and then paste the code for bb boards in the post
OK thanks. Will do that.
