Many thanks ofiras !
Just update to Buster beta with Tidal Connect support !
A lot of headache making Alsa work again with peppyalsa to support all the services: AirPlay, MPD etc . and also the IR control made me a lot of problems. but hey, that all the fun with those projects, isn’t it?. Now everything is working perfectly.
thanks to Volumio developers team for Tidal connect , its really cool.
Still don’t believe that you actually wrote Quarantine 19 on the faceplate. LMAO. Great Job BTW.
Cheers
Arnd
Hi ofiras,
just found your beautiful first project. Although it is about 4 years old, you probably still have your customized 20x4 LCD-plugin. I am looking exactly for that solution but am not capable of doing it myself.
Could you please share it?
Thx in advance + kind regards
Matthias
I didn’t make a new plugin from it I just used the code of it and made some modification.
You can take it from the git . If you have knowledge with python , It is very easy
Sorry, I can’t get it running. Could you probably share your solution/modifications here or on github? Could be useful for others, too.
Thx and all the best for 2025!
lcdcontroller.zip (368.9 KB)
Thx so much.
