Friends,
the super capacitors and 3.3V control board from IAN CANADA have arrived.
I have to honestly say that this is a real upgrade for the audio chain!
Powering the sound card and Isolator III.
Friends,
Man, this is a thing of beauty. You’ve inspired me to build one now (so I might ask a lot of questions)
I want to build a Roon ready streamer and display on the screen. Have you tried Roon?
I’ve jst ordered a hat with I2S as I’ll want to play native DSD. Once I get it all working I’ll then start the build, as if I can’t get it working then I won’t.
With the case, did you get them to cut the front plate for the screen? I’ll be doing the same if so.
Simply awesome detail. Well done
Hi, thanks, I haven’t tried RON.
I use IAN Canada ISOLATORPI III but without DSD module,
it doesn’t work with my sound card! Confirmed and consulted by the author of IAN Canada .
I had the hole for the LCD and the back panel custom-made on CNC directly from the supplier: Drilling
