Music stop playing
We are using a Raspberry Pi 3 with Volumio as a background music player but even though I have selected the Random and Repeat/Replay option in the Queue screen, it still keeps stopping at the end.
Am I missing something?
When I’ve had that, I think it was because I had unplayable files (maybe there were corrupted??)
Is there are tool within Volumio that will scan a library and report on corrupt files?
Linux can scan folders. There are probably tools for Mac and Windows. But I haven’t used them.
But next time it stops, try playing the same file with another player. See if that works.
Also what if you just try to play that specific file by itself on the Volumio.
