Music Library Synology NAS and Volumio 2
Hi everyone,
I just want to give a solution I had setting up my Music in Volumio 2.310 using nfs on my Synology NAS DS214+.
When I followed the guide for setting up my library using nfs my RPi 1 Model B+ hat Errors mounting the music folder.
In the end i found out what the error was. As said I’m using a Synology NAS DS214+ with the OS DSM 6.1.4-15217 Update 1.
It seems that the NAS doesn’t like the wildcard anymore which is suggested in the guide.
In my case my IP Space is 192.168.178.*, but entering this wildcard in the NFS Permissions under the Shared Folder Settings didn’t work.
The solution was to point directly to the device, in my case 192.168.178.60.
Because I didn’t find this solution anywhere else I thought it would be nice to share it.
THANK YOU SO MUCH!!!
That was the only solution that helped me - and I have been searching for hours and hours…
