Hi Community,
just wondering it seems since a recent update, (can’t tell which one )
The available menu list under “Music Library” only content one available link : “USB”
Previously, I was able to browse my whole drive over there.
Can any one explain this ?
Currently on 2.777 on Pi 3.
Thanks,
Pascal
I assume that you’re accessing a cifs/samba share, when you talk about your whole drive? Try setting the vers number as shown in https://volumio.github.io/docs/FAQs/Audio_Sources.html
Hi chsims1,
nop, this is a “local” disk. It is a 400GB sd card, with a second partition and added into fstab. This config is working for “years” now :
/dev/mmcblk0p4 /media/Music ext4 rw,nosuid,nodev,noatime,data=ordered,uhelper=udisks
I noticed it is now appearing after a 3d request for “Update” in the Source screen.
Appearing under “USB”, where this was empty for several days.
Thank you
Ah ok, but you’re now sorted? If so, just click ‘solution’ under the options in your last post, so that we all know the problem is sorted.
Done,
thanks again,
Pascal
